Old 09-14-2011, 12:21 PM   #61
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by twk-b View Post
Overall everything went really well, I finished off the adding/delete/update for multiple cars. Will be adding copy and code to migration your existing profile to a setup tonight.
The changes I made for the display look way better as long as you are using a 3.7" screen (yay android fragmentation!). As the display problems have been the biggest reported problem I have ripped the UI apart last night and have something that handles resizing much better now... it needs a little more polish before release but I should have the finishing touchs completed tonight or tomorrow....
Cleaned up a bunch of unused includes which reduced the memory footprint further.
-b
-b
When should we see the update applied?
It's been a long time and I feel this should be the program of choice but so far have yet to be able to use it due to the graphics issues.
Looking forward to the update...
YoDog is offline   Reply With Quote
Old 10-24-2011, 07:03 PM   #62
YoDog's Avatar
Bernie,
What's going on with the app?
You said that an update was days away from release and it's been over a month now and there is no update.
Old 10-26-2011, 03:37 PM   #63
twk-b's Avatar
Send a message via MSN to twk-b
Default The Twitch is a coming..
Originally Posted by YoDog View Post
Bernie,
Thanks for the encouragement...
After the last major push of effort, I got all the multi car stuff working and probably should have released it, but got over zealous and started on the huge UI update. Unfortunately to take a step forward the UI took a huge step back, and it was a real mess, then I ran out of time...
Your note motivated me.... Last night I stayed up until 4am and carved out a bunch of stuff.. add/remove/delete is all tested, renaming has been added. buttons have been replaced with menus (invoked with the menu button)...
The main screen now shows pinoin/spur, FDR and rollout for each car.
I fixed a memory leak for the database connection that was causing the program to crash at times finally.
That leaves me with just Copy/duplicate menu option so you can duplicate an existing configuration, similar to that I need the piece that converts your existing configuration into a saved configuration. Those couple things will take less then an hour to finish off as they are just special cases of saving...
The layout has been converted to table layout... and it appears to work much better now after being beaten with a mallet! Last night I tested it on Android 2.1, 2.2 and 2.3.3 and it now works (and numbers are legible)! I was only testing with 3.7" screens, so the last part is to test some more screen sizes to ensure that everything is scaling properly.
If you have a device with a screen size smaller then 3.7" and have already bought the app please send me the details of your device (model/brand and screen size) and I will do my best to get it tested....I downloaded the new SDKs for Android 3.x (for tablets) and 4.0 for phones and tablets, but did not yet test on those devices. I will take a look at how it looks on them, but Tablet support will follow in the next version probably (unless its trival or just works .
Another day or two of testing and it will be release. Sorry for the delay.
I really appreciate the support.
Bernie
twk-b is offline   Reply With Quote
Old 10-26-2011, 05:29 PM   #64
YoDog's Avatar
That's great to hear Bernie!
I would have been happy with just being able to see the numbers on the MyTouch 4g. I like the app as it is so I am eagerly awaiting the updated layout. I just wish I could have put it to use from the get go.
Old 11-03-2011, 12:16 AM   #65
YoDog's Avatar
Bernie,
Still no update showing up on the market.
If the update is not going to happen for awhile, please make that statement instead of getting our hopes up with this talk of just a day or two to go. I can appreciate that it takes time to work out the bugs and make it right, I understand. If you are busy with your "real job", I get it...
All I ask is that you follow through.
I look forward to your update when it becomes available.
Old 11-06-2011, 11:03 PM   #66
twk-b's Avatar
Bernie,
Update has been posted to the market, just waiting for it to show up, should be any time soon. Probably be a bug fix or two around the corner.
Just updating the photos in the market now..
-b
Old 11-06-2011, 11:19 PM   #67
YoDog's Avatar
Awesome news Bernie!
I will keep an eye or two out for it.
Thanks for your hard work.
Old 11-07-2011, 01:24 AM   #68
YoDog's Avatar
Bernie, the first bug is that after updating, my phone says the app is not installed.
I uninstalled and then updated again with the same problem.
I'm going to restart the my touch and see if that corrects the problem.
I restarted the phone and the app now works! Just had to replace the shortcut on my main page as well.
Thanks Bernie, It looks great and I've already started to create more profiles for my cars.
Nice job! P.S. everybody should get this app it's definitely worth the price.
Old 11-07-2011, 07:21 PM   #69
twk-b's Avatar
Thanks again! If you haven't already I would really appreciate positive feedback and a 5 star rating!
Android market has updated the details in a big way.... here are some stats
50/50 split between mostly 2.2 and 2.3.3 version of android
in United States, Australia, United Kingdom, Sweden, Canada, Japan, Norway, Denmark (c'mon Canadians 5th overall?!)
Should be a couple of smaller updates coming over the next couple of weeks.
-b
Old 11-07-2011, 10:16 PM   #70
twk-b's Avatar
added a google+ page. whoot!
https://plus.google.com/101450980705787413117
Old 02-20-2012, 07:23 PM   #71
twk-b's Avatar
Default version 4.0 released minutes ago to android market...
v4
* - added: improvements for tablets (transformers/prime)
* - added: volume works on gear chart page
* - added: rename setup
* - added: copy setup
* - added: transponder number field
* - added: spur/pinoin turn red when outside axle min/max
* - bug: fixed display error for "Add Car" button
* - bug: Exception in Android Market Dashboard (java.lang.NumberFormatException on Diameter+/-)
* - bug: fix for delay +/- functionality
* - bug: fixed gear chart to not always show 48P 25/87
* - bug: saving wasnt always working, profile was never saved
* - bug: fixed display of speeds (boost max/min and motor max)
* - bug: 6 throttle profiles not 5
Carcar Ophidian Canadian R/C Scene 12804 12-09-2017 10:10 AM
Team Associated TC6 Thread Owen RaCing Electric On-Road 10291 12-06-2017 02:15 AM
KARZ Calgary xrayroooahhhh Canadian R/C Scene 19114 12-01-2017 01:26 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
