Team Corally RDX Touring Car
#8764
Originally Posted by wallstreet
you just have an older version of the 2.9 chassis
Fankoo!
#8765
Originally Posted by JAY_UK
Anyone know the part number of the 2.9mm chassis with the tape option?
Fankoo!
Fankoo!
#8766
I notice on one or two page back there is a car with blue turnbuckles which one is that? is it the TC4 or TC3?
#8767
Can any please tell me what brands of spur gears fit the adapter for the RDX? I know Kimborough does fit, but what other brands fit? Thanks everyone.
#8769
Hey Brian,
I have some RW gears too, but the mounting holes don't exactly line with the adapter, I'm wondering if I picked up an older spur gear. Do yours line up evenly? Thanks.
Brian
Brian
#8770
I have a question regarding the installation of a one-way.The directions state a "nub" has to be ground from both bulkheads to install the larger bearing housings.If I grind that nub, does that mean I can't go back to using a front diff and it's smaller bearings? Thanks for any help.
#8771
You shouldn't have to grind anything, the only thing you need to run a 1way is the larger bearings and holders for the 1way... that groove fits into both the diff/spool and 1way bearing holders
#8772
Originally Posted by or8ital
I dont think Corally updates their part #s when they make changes to existing parts. The new chassis requires dremeling as well. They have the slots but they arent cut all the way across. You gotta finish it. I believe that is correct. Take a picture of the bottom of your chassis and Im sure someone can tell you.
Yea Corally for updating and not obsoleting
The older tower is on the top in both pictures.
