Team Corally RDX Touring Car
#8402
Originally Posted by jordys jrxs
hi, where can i get the metal mip cvd blades from cos ive got a spool in my car and i run stock and super stock and i just keep breakin the plastic ones
jordan
jordan
http://www.corallyusa.com/specializedrc/rdx.htm
#8403
Jeff,
Is tosolini coming down for the kopropo race
#8404
Originally Posted by andrewdoherty
An answer and a question.
Dunno about the gearing on asphalt (on carpet with a 90ft straight we run a 6.36 or so with monsters which would be a 100/31 or so) but you don't have to use corally gears. I happen to like Kimbrough simply because theyre everywhere and cheap.
Harsh, Jeff, shushi Brian and company . . . what diameter turning radius you end up with when running foam on carpet? With what ever radius you use to race is there "room" to turn up your epa's or DR to get the wheels to turn further or are you running at max? just curious
-Korey
#8405
Hi I am trying to help out a fellow racer with his RDX and would like to ask you guys what the WT of the shock oil that came with the kit is? I think it says medium on the bottle. Another thing he is wondering is how the droop should be measured (numbers in the 6mm range or according to the instructions). In fact what he really needs is a good starting setup for low grip tarmac/asphalt using rubber tires, so if anyone could help that would be great.
Regards,
Emil
Regards,
Emil
#8408
hey emil this is my starting setup for low grip tarmac
front:
springs: 17 lbs.
shock oil: 35 wt. trinity
shock position:
top: 3rd hole in on tower
bottom: outside hole on old arms
camber and position:
camber: -1*
pos.: top row, 3rd hole in
droop: 3mm. above ride height, measure with wheels on, w/o shocks on
ride height: 6mm.
front drive: diff unless traction starts to come up then one-way
rear:
springs: 14.5 lbs.
shock position:
top: outside hole on tower
camber: -1*
outside position: kit hole on hub, i.e. second hole up from bottom
droop: 4mm. above ride height, measure with wheels on, w/o shocks on
ride height: 6mm
rear drive: diff
with rp30's all around
-Zac
front:
springs: 17 lbs.
shock position:
camber: -1*
ride height: 6mm.
rear:
springs: 14.5 lbs.
shock position:
camber: -1*
ride height: 6mm
rear drive: diff
-Zac
#8409
Originally Posted by Sushi Boy
I have my endpoint set so the wheels are just shy of locking... or hitting the shocks. I never change it.... I never use expo.... I just leave it. I'm kinda of weird... I never use the entire wheel. I only use about 1/4-1/2 of the wheel. I really like my cars to be really aggressive since I generally have fairly smooth inputs.
-Korey
-Korey
Thanks for the input./ I think I am like you in that I want to have more sttering than I need available and then only use what I need. Are you using one of the generally accepted setups from corally's site for foam/carpet? Sorry about the mispelling also.
Shushi LOL "Doesn't anyone care for shid the shloth?"
-Ice Age-
#8410
bearings
hi, wot do you guys do for your bearings??
do you take a sheild out and flush them and re-oil them
or do you try flush them out with the shield's in
or do you not touch them
jordan
jordan
#8412
Ride Height
I have just finished building my RDX and I noticed that I can't seem to get anything under 6mm ride height in the front of the chassis. I have the lowered shock tower in the front and even with some old short tires the ride height seems too high. Any tips?
#8413
#8414
How much do you cut off of each shaft and eyelet?
#8415
