Team Corally RDX Touring Car
#7621
Sorry for all the questions but should I put a small amount of thread lock on the steering knuckle pivot screws?
#7622
Greetings ollie
#7623
Its just the thread does into metal so it could come loose it shouldn't make the steering bind.
#7624
Greetings Ollie
#7625
#7626
Originally Posted by syndr0me
Are you talking about the M5 kingpin screws? A little blue threadlock is okay as long as you don't get it into the portion of the pin that the steering blocks turn on. Once I got the proper sized driver, though, I never had one come loose, and quit using messy threadlock. Corally makes a nice one in the appropriate size.
#7627
#7628
Yes those as you have said its cause I dont have the right driver. What size is it?
Jeff
#7630
Has anyone got a kit setup sheet in pdf?
#7631
Heard that the new arms are breaking just as easily as the old arms, just in a different place. Sounds like they need to beef up the area around inner hinge pins.
#7633
rubber no one-way anyways im sure sushi has a good one for you but i will start whit Jason RDX Setup!! go see it at corallyusa.com
and when you run rubber you need a one-way hehe!! it like a rule lol
later!
later!
#7635
later!
later!
It sucks , but that is one of there rules to " keep cost down"
