Team Corally RDX Touring Car
#7366
Originally Posted by syndr0me
I've got some of the braces on the way (for the rear). They're cheaper than a single shock tower. :-) Give AB Charles a call if you need some, it's a good group of guys out there.
sent you an IM with tracking number.....
jim
#7369
Smoother schocks
Originally Posted by Sushi Boy
Just makes the shock a little bit smoother
-Korey
-Korey
I have in one month time a important competition (against Hupo Hönigl, T. Pumpler, M. Hudy, Pinnisch and a lot more - Austrian Championship) and I am trying to get the best options for a high speed , good grip big asphalt track on control tires (C22 with most using Orion yellow or Echo pink)
If you can give a tip for the oil (like 50w front and 30w - Asso rear, it is also mostly wellcome
cheers
Pedro
#7370
Tyres
Originally Posted by TRF415boy
He's talking about the steering bellcranks. The plastic ones you can get from -10° to +10° toe with just twisting the wheels with your hands. So if you're using the plastic steering bellcrank this is more likely your problem.
This being said, you mentioned using CS27 and they're certainly not helping you. Depends on your application (with controlled tyres or not and how many runs a set you want), you might want to switch to either CS22s (NOT the new preglued, better nothing than that, but if not preglued and low amount of runs, they're still the best and will provide plenty of steering, use hara greys or echo yellow inserts in them), RPs (24s or 30s depending on how many runs you want and how much steering you want, 24s more steering) or Sorex 32s (less steering than RP24s, dunno compared to RP30s, a lot more runs than RP24s or CS22s).
thanks in advance
Pedro
#7371
Originally Posted by josh short
i need some gearing sugestions i m racing stock and 19 on asphalt the track has 160 foot straight right now im at 6.00 (FDR) for 19 and 6.50 (FDR) for stock is this close thanks
What style motors are you running??
Sounds right for a C2 and a monster.
#7372
Originally Posted by Mr. McGoo
here are pics of Team Tamale's shock tower braces - it is just with my camera phone....so sorry for the so-so pics
PIMPTASTIC!!!!
#7373
Originally Posted by Drcy
Thank you , but ..which make the schock smoother, the tamiya or the new rounded ones?
cheers
Pedro
cheers
Pedro
For asphalt I generally run 40wt oil all around. It makes it have more mid-exit steering. Your track is probably bigger than mine though, but try it and see how you like it.
-Korey
#7374
For you guys running the offset bulkhead, do you find that you need to put less weight on the right side of the car to balance the chassis? I'm sticking to my guns on running brushless, but that thing hangs SO much weight off the left side, I can't get the chassis to balance.
I just kind of assumed I'd need less weight on the right, but since I already ordered it, I hope that was a correct assumption.
#7375
Syndrome.... moving the motor in some will make alittle difference..how much i am not sure.....most likely it will make more difference on tight technical tracks as opposed to wide open ones...
Jim
Jim
#7377
yes
#7379
In your opinion, at around 20Celsius, middle grip, very fast track, modified 12 turns, with 1 set of tires for 2 runs - WHAT would be your favorit tires/insert combination (I like C22 with Proline rims and Echo Pink + Tire Tweek) ??
thanks in advance
Pedro
thanks in advance
Pedro
