Team Corally RDX Touring Car
#6151
Originally Posted by Customworksking
based on the Novak stock foam setup what changes do I need to try/make for Med to low bite on a small track 36X70
The only chage from the Snowbirds setup I made was to move the steering tie rods onto the inside hole on the steering bell cranks!
#6152
car
Originally Posted by koabich
I would use the newest from the Snowbirds. I used this setup last week and it was perfect on my local tight carpet track! Use the extensions and lighter springs in the rear!!
#6153
I was told the novak setup was the same do U have the Birds setup?
It's listed there!
They could be the same...I'm not sure!
#6154
Wonder if you can help,
Got some "slop" problems with my steering. If i hold the left, or right, i can still turn the one im not holding. I checked that the steering levers were tight and they are. What else can it be? Its quite hard to set-up when you can get a accurate Toe-In reading.
#6155
Jeff
#6156
Jeff
#6157
Ok thanks Jeff. Ive heard that Shui or RPM bullcups are quite good at stoping slop? What do the team drivers use?
Will
Will
#6158
Will
Will
#6159
Originally Posted by Jeff Brown
Weird..... I have not posted setups from 2006 Snowbirds. Mainly because no one has provided me with them. They really have not changed much since Novak anyways.
Jeff
Jeff
Opps, my mistake...then it was the Novak ones I was using. They are pretty much perfect!
#6160
does anyone know where i can pick up som duraluminum steering blocks - they seem to be back ordered - so if any of your LHS have them in stock, please pm me -
i have a big race coming up and i need to make my car as bullet proof as possible -
thanks,
marc
thanks,
marc
#6161
Will
Will
#6162
thanks,
marc
thanks,
marc
#6163
thanks,
marc
thanks,
marc
