Team Corally RDX Touring Car
#5896
rdx parts fast
hey guys i need to know the best place to order rdx parts. i need a few things by thursday.
#5898
thanks korey i'm checking for chase he needs a diff and a bumper mount, and deb is closed today.
#5899
#5903
Just wondered has anyone had any success using a different ACKERMANN angle to the Std . ?? I've set mine up with a 44mm center link per the instruction but just wondered if anyone else has found a long/shorter link to work better ??
Cheers
Rod
Cheers
Rod
#5904
I've always liked the standard setup. I've used the inside hole on the steering bellcrank before. It basically made the car feel smoother, and had more high speed steering. The tires just stayed more parallel to each other. I ended up going back to the standard ackerman setup anyways....
-Korey
-Korey
#5905
Sorry but change of subject. Today i finally got all of my needed electronics for my car that i haev always wanted. and i wired teh car up, into the receiver, etc. all i can say is wow. this is THE tightest chassis i have ever worked on, but you know what? this is one of the best wiring jobs ive done, and the car is so nice right now, im just happy. the car is really tight compared to other cars that i have wired up, and that is a good thing
#5906
-Eric
#5907
-Korey
-Korey
The ONLY inboard ankermann adjustment i can see is adjusting the length of the center link per the manual
#5908
Originally Posted by Merciless
How'd you manage to use the other hole ?? the diff's in the way on my car !!
#5909
IRP
-Korey
-Korey
