Team Corally RDX Touring Car
#5566
Originally Posted by RDXracerboy
I have a question about my shocks.. This has happened to me with my previous cars before, so thought it was just normal but now I want to ask since these shocks are much better then my previous. When I rebuild them, and fill up with oil they have nice preload.. but then when I stick them on the car and give it just one run, and take them off the car the pre load is gone... I haven't noticed any leak and was wondering if this is normal? Or am I not rebuilding properly? Thanks for any replies..
Hope this helps
Brett
#5567
Originally Posted by BrettBowen
There's a good chance your shock bladders are turning inside out. Is it all 4 shocks or just the fronts? With the lowered shock tower in the front, I cut about 1/2 of the threads off the shock shaft, and actually shortened the shock end as well. This way the piston runs more in the middle of the shock body, instead up right up by the bladder. Also, you can try running one of the foam "dots" that several companies make on top of the bladder, that will keep it from flipping inside out, or caving in at all.
Hope this helps
Brett
Hope this helps
Brett
#5568
i build my shocks to be completely dead, no rebound at all, i save that for the springs
#5569
#5571
Thank you for the suggestion Riketsu! Makes sense.. I do usually have high rebounds when I rebuild.. thanks.
#5572
I'm having an issue with my car and I'm getting very frustrated. I just got the 3.9mm chassis and I'm putting the car back together and I install the steering post only to find out that it hits the front bulkheads. Am I doing something wrong here? You'll also notice that where the steering posts mount, it is not milled down, is it supposed to be? Any help would be great! Thanks!!
#5573
shocks
Originally Posted by Riketsu
When you rebuild em, try to go with much less rebound. A normal shock should only push out about half the shock shaft. If your rebound is high, then when your running the car, the seal will turn inside out like brett said.
#5574
[QUOTE=kabttu]I'm having an issue with my car and I'm getting very frustrated. I just got the 3.9mm chassis and I'm putting the car back together and I install the steering post only to find out that it hits the front bulkheads. Am I doing something wrong here? You'll also notice that where the steering posts mount, it is not milled down, is it supposed to be? Any help would be great! Thanks!!
I got my car already assembled, but from looking at it, I see that my chassis is milled out around the steering posts. I would call corally, or the lhs you purchased it from and ask them. Is it a corally part or not? Just curious.
#5575
#5576
#5577
#5579
Regarding the clearance......
We had a few chassis that had the milling removed from the bellcranks in hopes to fix the bump steer angle on the steering link. Well, it obviously hits the bulkhead. We stopped shipping those and sent the ones we still had back to be fixed.
You simply have to dremel the nut and screws a bit to make clearance. Justin Zorc ran this exact chassis at Novak and finished 4th with it. Only has to be dremeled like 1mm or so.
Jeff
Jeff
#5580
Jeff
Jeff
