Team Corally RDX Touring Car >
Old 01-20-2006, 10:01 AM
  #5206
Customworksking's Avatar
Trader Rating: 74 (100%+)
Post super low
Originally Posted by RCFREAK
CUSTOMWORKS......im glad you got your RDX all hooked up!! i still have my second car. and it still is running great. a while ago you were interested in my first kit i had for sale... glad things are going well with your RDX!! keep it up, it only gets better!!! i tried a standard rear low roll center in the car with ultra lows in the front... that actually frees up the car more in the rear.. i almost always run it that way nowadays.
When I got my rdx I was told that it has the super low blocks on it but I'm not sure if it does or not because as it sits now from the bottom of the block to the top of the chassis theres about 1.5mm between the block and the top of the chassis so, are the super low blocks even lower or are they the right blocks ? any help will do thanks
Customworksking is offline
Old 01-20-2006, 10:09 AM
  #5207
Turbonium's Avatar
Trader Rating: 27 (100%+)
if i remember right, the ultra-low blocks sit right on the lower deck, barely any gap at all. someone else might be able to be more exact till i get home and look at my foam tire car....
Turbonium is offline
Old 01-20-2006, 10:11 AM
  #5208
Brian McGreevy's Avatar
No there is at least 1 mm of air under the blocks...probably more like 1.5. I've never measured that.
Brian McGreevy is offline
Old 01-20-2006, 10:47 AM
  #5209
Big Rigg's Avatar
Is the www.corallyusa.com site down? What's the phone number so I could call and make an order?
Thanks!
Big Rigg is offline
Old 01-20-2006, 11:16 AM
  #5210
Go here http://www.corallyusa.com/2005/core.htm
The number is 407-681-5905
Old 01-20-2006, 11:59 AM
  #5211
Trader Rating: 19 (100%+)
Thanks!
I can't resolve the name so I would think it is a DNS issue.......
Anybody have an IP address for the server?
Advil is offline
Old 01-20-2006, 12:38 PM
  #5212
HarshGuy's Avatar
yea
206.get.over.it.they.must.be.down
HarshGuy is offline
Old 01-20-2006, 05:14 PM
  #5213
Jeff Brown's Avatar
Yeah, I called our server people. Apparently someone out in the Nevada desert decided to try and steal some Fiber Optic cable, about 1000FT of it. Problem was it was buried in the ground so their pickup truck seemed like a good option to yank it out.
I think it took down like a wide scale regional area for the Sprint network. Idle hands I tell ya......
Jeff
Jeff Brown is offline
Old 01-20-2006, 07:21 PM
  #5214
HarshGuy's Avatar
Jeff
Nice ...probably a couple of dudes with missing teeth and banjos.
HarshGuy is offline
Old 01-20-2006, 07:40 PM
  #5215
Matt Howard's Avatar
so that's where scotty and dal went the other day
Matt Howard is offline
Old 01-20-2006, 09:35 PM
  #5216
Soviet's Avatar
So whats the story on the RDX??? Is there a new "upgrade" kit coming out for it or what?!?! Inquiring minds WANT to know!
Soviet is offline
Old 01-20-2006, 10:41 PM
  #5217
Jeff Brown's Avatar
You don't pay attention do you. heh. Same dialed RDX. No "upgrade" kit. No need for it.
Jeff
Old 01-21-2006, 12:46 AM
  #5218
Soviet's Avatar
Jeff
Actually I've been busy for the last week or two...I thought there was somthing coming out for the car that would address arm breakage...
Hmm...so the whole "suprise" was just Ti screws and a motor guard??? Hmm...letdown.
Soviet is offline
Old 01-21-2006, 06:39 AM
  #5219
Mission_carbon's Avatar
Why would you need a "upgrade" kit if the RDX is fine as it is like Jeff said? . Pointless really....we dont want to be like Xray bringing out the FK05 then shortly the T2
No need.
Will Olpin
Mission_carbon is offline
Old 01-21-2006, 08:04 AM
  #5220
FBJ's RDX's Avatar
Jeff Brown: Hi Jeff, I would like to know what the effect would be if I make my rear roll center 2 & 2 on the rear bulk head? Will it give more initial rear traction upon entering a corner? Or would it add to over all steering? Thank you.
FBJ's RDX is offline
