Team Corally RDX Touring Car
#376
Nope, can't help you with that no carpet down here!!!!
CorallyUSA has some setups online though.
#377
ok guys car was awesome as soon as it hit the track it was really good. i was ending harder then my car in the past, motor was coming off cooler. Car had slight push going in made caster change and roll center and teh car came right in. Looking foward to the birds and nats. Im going to the Nats track tomorrow to get some time on that track. Ill keep u guys posted on setup that i find there. feel free to ask questions. lata
jeff
jeff
#378
Jeff, I already have 6* caster blocks if I dremel my blocks at 45* and redrill the hole at 90* will that give more onpower steering . Also I hear you tried 1 way bearings in the rear,what was your thought there.
I hope to meet you at the indoor nats
#381
Jeff, When you run foams do you apply tire bite in direction of tire rotation or reverse,and how do you wipe.
I see your the stock King so what do you suggest for stock roll out for a med size track.
Good luck with your new car,I know your gona wheel it to the front.
Is it true on race day you never chew gum
#384
CDX carpet setup
hi Jon
Here in the UK, I am running on carpet using schumacher carpet dragons rubber tyres. On front 24lb springs, 60wt oil, 4deg caster, 0 kickup, diff and not a one-way. at the rear, 17lb spring, 30wt oil, 2deg toe-in.
I get plenty of steering into corners, so am considering a solid axle in the front, and then going softer on springs and oil on the front.
#388
Mo Dizzle's RDX is dialed. I believe he has her figured out boys...
#389
Yep new team member Curtis May, layed it down today!! Good job Curt!!!
#390
this might be soemthing to try for carpet:
front;
shocks layed down on the tower, outside hole on the arm
70 weight, 33.5 pound spring
short camber links
optional low roll center blocks all the way around
ackerman, outside on the block and outside on the bell crank
75 percent arms
diff up front
Parma Cyan tires at 2.24
ride height 4.5 MM
shock tower lowered .130
rear;
shocks one hole from all the way outside on the tower
outside on the arm
30 pound spring with 50 weight and stock piston
1.3 mm sway bar
1 degree rear toe
camber link one hole in from the outside in the lower row on the tower and same on the hub
parma magenta 2.24 tires
wheel base is short
carpet is med. bite with nifetech traction compound
this set up works awesome in stock and 19 turn
and in 64 pitch a 104 is the biggest spur that fits while running a rear bar.
hope this helps anyonw for a carpet setup with foam tires
oh yeah parma alfa body
thanks
Mo Denton
front;
short camber links
75 percent arms
diff up front
ride height 4.5 MM
rear;
outside on the arm
1.3 mm sway bar
1 degree rear toe
wheel base is short
thanks
Mo Denton
