Team Corally RDX Touring Car
#362
the car has not made it to the U.S. yet, but from what i have been told, the chassis is made of 3.5 mil, or close to it carbon fiber and it comes with a diff in the front instead of the 1 way.
hope this helps
hope this helps
#363
Actually......... the brochure on the CorallyUSA site has the specs for the Carpet Spec car. CorallyUSA has the double diff version of the standard car in stock. Which is the same car that Tosolini and I ran in Cleveland. The Carpet spec car is still 3 week away at least. We are waiting on the chassis to be cut. Everything else is in place.
If you have any other questions let me know.
Jeff
Jeff
#364
Carpet Specs: 3.5mm milled chassis, 4 deg blocks, Xtra Hard Suspension Arms, Double Diffs, Stiffer springs.
#366
Jeff Brown, sorry for all the questions but I see that Tosolini (on his Cleveland setup) was running his front shock tower lowered, is this a new shock tower or did he modify the stock shock tower to lower it??? Also what did this do for his car???
I just ordered my car and I'm trying to see if I got everything I needed....
Thanks....
Thanks....
#367
Tech Legend
Trader Rating: 51 (100%+)
Thanks....
Thanks....
#369
I ran 2 deg rear toe. I thought I put that on there. I'll fix it later. The wheelbase, i ran it in the middle position. So one clip in front and behind the arm.
Toso drilled some holes to lower it a little bit. He wanted to get the camber link flat to help keep the car flat in the corners.
Jeff
Jeff
#370
Tech Legend
What....it's for a friend....
#374
Originally posted by Jeff Cuffs
Just finished building the car, went together great. Ill be doing some testing tomorrow at my local track and then im going to the track that the nats will be held this year. Ill keep u guys posted on a carpet setup that i come up with. talk to u guys lata.
jeff
jeff
#375
Well it looks like I will be seeing more than just one RDX running on January 29th. We'll see how it does in the hands of Cuffs and Teach.
http://home.comcast.net/~idw/race29.htm
