Team Corally RDX Touring Car
#2627
Originally Posted by stiltskin
I keep seeing posts on a "lowered shock tower".
How do you lower the front shock tower?
Insane
#2628
you drill holes slightly higher up than the stock holes where they mount to the bulkhead. The distance between the orig hole and new hole is abotu the same distance between the upper row of camber link holes to the bottom row. This way when you lower it and use the top row of links the position is similar to that of using the bottom row on the standard tower. you have to trim a little bit off the bottom of the shock tower as well. Now just flip it around so the counter sunk parts are facing the bulkhead and just use button head screws to fasten it to the bulkhead.
-Korey
-Korey
#2629
me too i was not able to set the ride heigth at 5mm but now i can!!! i use spring collar of the xray and now i can adjust the ride heigth!!
Later!!
Later!!
#2631
no problem!!
Later!!
Later!!
#2632
Hi, I built and raced my RDX just this past weekend. I was really impressed by it. It performed really well. One thing I noticed about the car, though, was an excessive amount of play in the front chubs and rear hubs. I'm not sure how that affected my handling but I'm gonna go shimmin' tonight. I was just curious if anyone else had that problem and if shimming helped performance?
#2633
#2634
#2636
1st-is there any blue turnbuckles that will fit on the RDX???? like the blue one from associated or tamiya???
2nd- i want 1.3 piston and just want to make sure if i drill a hole whit a 1.3 mm bit it will be the same???
Later!!!
Later!!!
#2637
Later!!!
Later!!!
#2639
the associated one is not too long???
and also do they will fit whit the RPM turnbuckles cap???
speedxl can you send me a pics of your RDX whit the blue turnbuckles???
Later!!!
Later!!!
#2640
pitchers
helo all
can some people put some pitchers up of the rdx as i am thinking of geting a new car and this is one on my list , and would like to see what it lookslike with all the eletrics in
thanks bob
thanks bob
