Novak GTB 2 Sportsman ESC
#121
Yes. Yoh just need a good soldering iron and some skill. I regularly cut the wires to the exact length I need for esc, on-off switch, and servo. I then resolder them to the circut board.
Unsolder the wire from the circut board, tin a new 14gauge wire and solder back to the circut board. easy peasy
#122
#124
Hi guys,
I have the Turnigy TrackStar SCT 4.5T Sensored Brushless Motor 4550KV (550 size) comming my way.
Is the Novak gtb2 a good enough esc for this motor?
#125
according to the specs, a 3.5 is the limit for the speedo with a 540-can motor...if you're running a 550-can (which I think most SCT motors are, I could be wrong), then you're right at the speedos motor limit - and I wouldn't recommend it
even with other speedos (like the tekin, which I've run for years), the chassis the motor/speedo is going in also plays into the motor limit - which a lot of time, the manufacturer doesn't include
so I'd see if its possible to get a different motor, or maybe look at another speedo
but that's me
#126
Thnx for this aswer, yesterday i orderd the hobbywing xerun 120A sct speedo so the Novak combo stays for backup...
I have used the GTB2 already for 2 years now with a Novak ballistic 4.5 and now i feel its time to let them rest and get on with something new.
#127
has anyone tried the Super Tuner Upgrade Brain Board in their GTB2?
http://teamnovak.com/shop/index.php?...roducts_id=469
just curious to see if its worth the $50
#129
