3Racing Sakura Zero S
#1471
I'm going to get the narrow arms, just want to make sure I can still use the rear stock swing shafts. Also, is this is the narrow arms from the sakura xi everyone else is using:
http://os.3racing.hk/products.php?products_key=5286
Sorry if this was answered earlier, but I won't have to change anything else if I use the narrow arms right? I've already made all the changes to increase rear grip (softer rear springs, increased roll center, 3* toe, camber, stand-up shocks), but I still want more rear grip.
#1472
#1473
#1475
You want the vertical motor mount part SAK-S17/PK.
The stock shocks are fine, but as you have the +4 shock towers they try the Tamiya TRF sedan shocks. Best in the biz.
I've tried the sway bars and didn't like how sensitive it made the car and took them off. That was indoors on carpet though so outside on asphalt mighe be different.
#1476
I'm building my zero and had a few ?'s
I ended up getting a lot of upgrades and with the vertical motor plate I had to dremal some areas for clearance to get it on and for gear mesh 84/42 64p so far I don't see a problem, but I saw that I can't use the 4 holes to put bolts through ,motor mount has none and opposite side does because its the stock plastic pc ,I figured to keep it uniform I'd leave both sides off so ..in total I have 4 bolts in and 4 out in the rear ..is this normal or ok ...
#1477
#1478
Did you use the vertical mount SAK-S17/PK? This part includes alloy parts to support the center layshaft on both sides. There are 4 holes in the stock upper deck that are no longer used once the stock motor mount is replaced and I've not had any issues. I did buy and install an extra alloy vertical upper deck post (SAK-57/PK) to ensure that there wasn't any additional flex.
Also with the grinding I did to clear motor the top deck looks to be weak ill post a pic later to show ..
Thanks tho ..
#1479
3Racing has multiple vertical motor mounts.
SAK-66/V2/PK is for the sakura zero as it already has a alloy stand opposite the motor mount.
SAK-S17/PK is for the sakura zero s and comes with an alloy stand because the zero s only comes with a plastic stand.
The one for the Zero S motor mount set only has holes for 2 screws while the stock one had holes for 4 screws.
The one for the Zero has no holes for the upper deck as the Zero upper deck doesn't even have holes to go to the motor mount. I don't have my carbon upper deck with me at work to show you the picture.
If you use the soft carbon upper deck SAK-38/WO it doesn't allow for any screws into the motor mount area.
I suspect that if you use the standard/hard carbon upper deck SAK-S16/WO you can put 2 holes into the motor mount. From what the pictures look like.
Here is a picture of mine. I'm using the original upper deck, which I filed down slightly. SAK-S17/PK the zero s version of the motor mount that comes with both sides. And you can
Sorry I know its confusing but this is the best I can explain it.
If you want a stiff chassis your best bet is to use SAK-S17/PK Motor Mount, and SAK-38/WO Upper deck.
If you want a softer chassis you can use either motor mount. and either upper deck.
Or you can do either and also go with SteveM 's idea, and just put in a vertical upper deck post (SAK-57/PK) with either setup to make it stiffer if needed.
That is the conclusion I came up to.
#1480
here is a pic
I am going to order a 2nd upper deck since i grinded this one down to much . if i can id like to get the other side pc also .
#1482
Not sure if there is any noticeable performance difference between running one alloy and one frp piece or not.
#1483
Finally had some good weather here in Norway, set a new fastest lap for myself!
With good in April I mean +5-7 degrees Celsius, so for you americans thats pretty cold I think for driving outside on the asphalt!
I had some problems with not getting enough speed out on the straight, but I think my front belt is a little bit too loose.
My best for the day was 15.8 with 13.5T blinky, which is a new class we are setting up in Norway this year. 13.2 was the best time set by a modified driver on the same track today. So I'm not that far off.
#1484
Need your help guys. I'm desperately trying to find a place that sells the SAK-32 aluminum rear bulkheads. Can someone find ANY in stock ANYWHERE ! ? I have all the other upgrades except this one. I'll need two pairs (for two cars). Someone please help!!!!
I've already checked rmart, rcmushroom, rcstation ebay...this forum etc.....
#1485
