3Racing Sakura Zero S
#1817
Does anyone know if these
http://www.amainhobbies.com/product_...-Spur-Gear-96T
fit? + will the holes be big enough to access the motor mount screw? Im trying to get away without having to buy the vertical motor mount.
Also are the 19t centre pulleys needed? Or has the front belt issue been sorted with the newer kits?
#1818
what servo are you guys using? for vta?
do you use the stock shock springs?
#1819
Learned a few lessons on the weekend and one of them being:
- make sure when you buy paint for the body to check the cans and not do what I did. Accidentally purchased one can of ts and one can of ps labelled paint. The ts doesn't stick to lexan and on the first impact it all started flaking.
Guess its easy to repaint now.
I've set up as per factory setup but too much toe out.
Does any one know the distance between the ball cups along the turnbuckles to get 1 degree toe out at the front. I'm ordering some ride height and camber gauges but they'll take some time to arrive.
I want to change the turnbuckles on the zero; which brands are the easiest to adjust?
Thanks guys
Thanks guys
#1822
#1823
new build
well I just finish my build of Sakura S
took about a day
I really enjoyed the build
some of the screws where hard to put in and had 2 that strip out on me.
(used visegrip to get them out)
dont have a track but ran it on the street and was very impressed
Im so happy with it im going to order a few more for other class's
so one upgrade im thinking was to get those dog bones out and swing shaft in
what would the effect be?
why would one use narrow chassis over standard one? what parts would i need to change or could I use stock parts
im looking for a few set ups -stock tc carpet
-gta carpet 21.5
-mod asphalt
thanks for any info
took about a day
-gta carpet 21.5
-mod asphalt
thanks for any info
#1824
took about a day
-gta carpet 21.5
-mod asphalt
thanks for any info
took about a day
-gta carpet 21.5
-mod asphalt
thanks for any info
For the dogbones... 3Racing just released their new SSK driveshafts for the XI DH (and the other 3Racing TC's), which will fit fine in the front of your car. Dog bone, vs cvd, against ssk... Basically as the wheel as more lock applied to it a normal driveshaft produces vibration. The more lock, the more vibration. Both the cvds and the ssk's will be better there, which means your inside front when cornering will be producing more grip.
The question is, do you really need either of those things? For 21.5, probably not. For mod, I'd guess so but I've never run mod before, just boosted 17.5.
#1825
took about a day
-gta carpet 21.5
-mod asphalt
thanks for any info
took about a day
-gta carpet 21.5
-mod asphalt
thanks for any info
stock parts will fit the narrow chassis just fine.
#1826
With the narrower chassis you can have more chassis roll, at a lower ride height without it scraping and effecting the handling. Also the CF has less flex, so less of it is needed to maintain the cars flex properties.
#1827
Chip taken out of FRP Chassis
Hey there Everyone,
Finished my Sakura S build 2 weeks ago, installed a 19t brushed motor Reedy motor and ESC I had lying around from my Team Associated TC4, charged up some nimh batteries and headed to the track.
I am very happy with how she handled, and was considering putting in my 17.5 brushless setup from my current tc4. Ordered and recieved the vertical motor mount, and started doing the modifications to the battery holders, when I noticed something on the battery side of the chassis:
A chip in the chassis!!!
I knew I should have seeled the outer rim of the chassis with superglue
Is there a way to repair the damage? If it is repairable, will seeling the rest of the chassis and will using a protective film on the underside of the chassis help prevent more damage? Or should I just get a replacement chassis?
I know I may be over reacting, but the Sakura Zero S is the first rc I have built from a kit since building my Kyosho Optima Mid back when I was younger. I have to say that the Sakura is definately a step up from running my rtr TC4.
Thank you all for all your help. This forum thread rocks!!
#1829
Thanks Shadowracer24 Will epoxy and see how things go
#1830
Hey guys I'm ordering a Sakura Zero S to run RCGT with, I'm going to order the car along with the vertical motor mount, spur gear adapter, 19t pulleys, extra arms and knuckles, and sway bars. Anything else I should get or have I got it all pretty much covered?
