3Racing Sakura Zero S
#1606
If anything thick front oil would cause a reduction in front traction and thus an increase in rear traction. Thick front diff oil will actually reduce steering response but it increases the ability of the car to pull harder out of the turns. This forces the rear end to follow the front again helping stabilize the rear end on power.
#1607
Yes but too thick = too much on power steering = oversteer = rear end loose on power, anyway different driving styles call for different setups i prefer more off power steering so i use thinner oil
#1608
Hmmmm. Guess my driving style is different. I run a solid axle up front and don't have any issues with a loose rear. Almost all of the drivers I know (sakura, xray, associated, etc) all run solid axles or 500000+ up front with no rear end on power traction issues. Maybe it has to do with when the power is applied. I'm usually on full throttle at apex or a hair after. I can see having issues if you get into the throttle a lot later in the turn where the front has a lot of opportunity to oversteer and bite way to hard on corner exit.
#1609
By the way what happened to the op? Haven't seen a post from him since the question was asked. Guess the rear wasn't that loose.
#1610
Ok i'll give the thicker oil in the front another go and see if i like, i have the x1 rear arms on now so rear slide shouldn't be an issue anymore
#1611
Just get on the throttle a ltitle earlier. You will probably love the way the car pulls out of the corners. If you nail the turn just right usually you can be full throttle at apex maybe even a little before. You will lose a little corner entry steering but you can make it up and more if you brake a little early and coast into the turn. Sway bars and springs can also help to get the steering back. Most of the time I'm still trying to get some steering out of the car on corner entry even with the spool. If you feel the rear getting a little loose under braking try a little stiffer front spring. I went so far as to add anti dive to the front to help keep the weight on the rear of the car. For some reason my car has never really suffered from a push on carpet asphalt or concrete. Now the f1 pushes like a freight train. Talk about a different driving style.
#1612
Sorry wasnt going to go through all 108 pages to find out. How is this car as far as reliablity? I dont mean hopped up versions i mean out of the box. I saw some issues with teh parts when you first get the kit? Im looking at this are the teh-r31. They both need a few things from the get go it looks like. Ive never ever assembled a RC car of any type so i would be lost if either of these would be tough to assemble. I am looking at buying a used roller that way i can at least reverse the build process to see how it went to gether
#1613
Buy a new one for the price they cant be beaten so why buy used, as for the build its a piece of cake follow the instructions and you'll be fine. Most of the hopups are more bling than necessary but hey parts are cheap so why not, just get the alloy spur adapter and 19 tooth pulley set and your good to go.
#1614
#1615
Anyone have a stock fiberglass chassis to sell....I need one after today. Some kid jumped over the roadrail and I hit him at full speed. Broke the front hinge pin holder and ripped the attaching screw threw the chassis. I don't see the stock fiberglass chassis listed at TQ racing?
#1616
Hi, Iīm running my Sakura Zero S in a small track with lots of corners.
Iīm using the manualīs Set-Up, and running with 100,000 CPS in front diff and 1000 CPS in the rear one, but a lot of times when Iīm getting out of a corner the car oversteers and spins completly.
A friend told me that I must use a 500,000 CPS grease in front diff and other friend told me that I must use 10,000/15,000. So I donīt know what is the solution.
Can you help me?
Thanks.
Can you help me?
Thanks.
#1617
Chassis
I have sent you a PM.
#1618
Can you help me?
Thanks.
Can you help me?
Thanks.
#1619
Hi, thanks for your reply, I canīt post URLs here, but my actual Set-Up is in the last page of the Sakura Zero S manual.
Regards.
Regards.
#1620
where can you buy this car? (besides hk) any place in canada? usa?
