Ofna Ultra GTP2e >
Ofna Ultra GTP2e
Ofna Ultra GTP2e
Old 10-01-2010, 09:07 AM
  #46
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Potoczak
Do any of you guys know where online I can find some 4s packs that will fit into the gtp. I took the measurements for the tray it is 145mm long by 54mm wide. I was looking for something 5000mah or bigger.
I don't think battery fitment should be a problem. The tray comes from the OFNA LX-1 electric buggy so it should fit any standard size 2s or 4s hardcase pack. The OFNA guys run 1/8th electric offroad regularly so I doubt battery fitment would ever be a problem. Just get any standard hardcase 4s pack.
Look here:
http://www.nitrohouse.com/catalog/in...03_407&&page=2
YR4Dude is offline
Old 10-01-2010, 09:47 AM
  #47
snellemin's Avatar
Trader Rating: 16 (100%+)
I have the older E-converted nitro version with the 44/14 diffs and these things can really go. I did however had to update the diffs with the heavy duty diff ring gears, as the stock onces did not last too long with the power overdose. I've ran 10s A123 with a 1512 1400kv tekno neu motor. I dragrace with 4s2p A123's and bash around with a 4s hardcase lipo. Motors use with the lower voltage are in the 3000-4000kv range. Torque wise, a 1512 size 4 pole motor or a 2 pole C50-L size Hacker motor are perfect. I've ran a 1515 2700kv Tekno Neu and it was just too much power for the poor diffs. I'm guessing the 43/13 buggy diffs in the GT2E should be the updated/upgraded version to deal with the brushless power.
snellemin is offline
Old 10-03-2010, 11:43 AM
  #48
Potoczak's Avatar
Trader Rating: 120 (100%+)
My work in progress!! Rx8 combo 2050kv motor, and will be getting some 4s lipo's, just not sure what to get yet.
Attached Thumbnails Ofna Ultra GTP2e-ofna-ultra.jpg   Ofna Ultra GTP2e-ofna-ultra-2.jpg   Ofna Ultra GTP2e-ofna-ultra-3.jpg
Potoczak is offline
Old 10-04-2010, 09:03 AM
  #49
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
That a nice esc motor combo I want to get that for my car.
I make a lot of Carbon Fiber parts for this car check out my website.
snrscion is offline
Old 10-04-2010, 04:28 PM
  #50
Trader Rating: 56 (100%+)
Still debating picking one of these up to convert to rally.
I could use a couple questions answered to anyone who has one it would be greatly appreciated.
Would it be possible to raise the suspension enough to get a bit of ground clearance to use for offroad?
How big are the tires, would I be able to throw some buggy wheels and tires on there?
How do you think one of these would hold up to some light jumps and offroad bashing? Im guessing since its based on the buggy itll be pretty tought.
Thanks guys!
Ride1226 is offline
Old 10-04-2010, 10:38 PM
  #51
kcunamay's Avatar
Trader Rating: 20 (100%+)
Still got some soldering and setting up to do, but for certain I will be ready for Corona
kcunamay is offline
Old 10-05-2010, 12:22 AM
  #52
Trader Rating: 18 (100%+)
What bodies will fit on these? I'm interested in a scale look.
omalley72 is offline
Old 10-05-2010, 01:02 AM
  #53
What sorts of motors and voltages are you guys running ?
i will start with a 2650kv motor and 4s packs to see how it holds up
ozace is offline
Old 10-05-2010, 03:14 AM
  #54
kcunamay's Avatar
That's the same setup I have in my car.
kcunamay is offline
Old 10-05-2010, 03:52 AM
  #55
Potoczak's Avatar
I am going to try a 2050kv setup. Will see how it runs with that in it. What brand of lipo packs are you guys running so far?
Potoczak is offline
Old 10-05-2010, 04:25 AM
  #56
kcunamay's Avatar
Trying to get into this class as cost effectively as I can. I am currently waiting for this pack to arrive. http://hobbyking.com/hobbyking/store...dProduct=10869
I've purchased several packs from them in the past and have been happy with them. Especially for the price.
kcunamay is offline
Old 10-05-2010, 10:08 AM
  #57
Thanks guys!
anybody?
Ride1226 is offline
Old 10-05-2010, 10:29 AM
  #58
YR4Dude's Avatar
Thanks guys!
The chassis is the same as the buggy. All you have to do is the make the adjustment to the shocks to allow for longer travel and add the necessary clrearances on your body for the buggy tires and raised suspension. You may also have to use the buggy springs which are longer and softer. Thats it.
YR4Dude is offline
Old 10-05-2010, 11:10 AM
  #59
Thanks. How much bigger are buggy wheels and tires compared to the stock tires? Also wondering if there is just an 8th scale car tire thats for offroad that would be better to use.
Ride1226 is offline
Old 10-05-2010, 11:15 AM
  #60
The inner diameter of the tire is the same. A buggy tire would fit just fine. Just find something with a low profile.
TYLORD is offline
