Tamiya TRF417
#6151
I did not try the 40 or 70. I'm pretty happy with the 600k the way it feels and turns so I don't think ill go that thicker and get the understeer again. Like I mentioned before I'm gonna put a small amount of 1m mixed with the 600k in it.
#6152
Do you guys use gear diff with putty/ heavy oil in high traction tracks? Like carpet?
Also, how much shock rebound would I want for low-medium traction carpet track?
#6154
Honestly I was going to go straight to ride 45, but then some one at the track told me he pretty much had to Buy a whole new gear diff when he was going to try some else so that's why I stayed away. Craig said it was easy to remove so I don't know. If I sell some stuff I have laying around ill buy a new diff and try it out.
#6156
Looks great joey!!
#6157
CraigM - so you dont suggest to drill the hole? :-) The new aeration damper has more negative rebound than the old one - I felt they are "dead". If the result by drilling normal TRF damper was very similar, definitely I wont try it for carpet, since aeration didnt work for me last time. :-( I assembled it as per manual w/o drill the hole, result 100% negative pressure. Normal TRF shock worked way better with 450 oil, 3 holes.
What do you think about Tamiya VG oils vs silicion oil?
Mr.Juarez - did you try ride putty? I have 40 and 70. What do you think would be similar in oil?
SS LS1 - thanks. I will try silicion oil as well. drilling - still considering to try or not :-). I have found a link in petitrc - trf 416 setings, which says to drill a hole in regular damper, but in the pro video he doesnt say anything. however in the link he suggest to have some rebound in carpet (5mm).....
thanks
thanks
I haven't run on carpet much but I think rebound can help when the grip comes up during an event
#6159
on low grip carpet the aeration shocks work wonders on my 417 (I made them as dead shocks, without drilling the caps, I have loads of grip. Infact I leave them on now when running high grip carpet I just dial out some steering. I have the standard ones I fit if the track is really high grip as otherwise I can grip roll. (This is 13.5 or 17.5) I dont run mod
#6160
I have a 417X for sale. Please check the link. Thanks
http://www.rctech.net/forum/r-c-item...s-trf417x.html
#6163
I have silicone leaking rear differential, I changed the-rings with new ones and still going well, you've missed even fat so that does not leave a silicone but still the problem
What do you suggest I use?
forgive me for my English
#6164
My diffs are leak free. You dont need the steel gear, plastic ones are fine as well.
#6165
So I want to switch to using the separate suspension blocks on my 417 but I don't see either on the Tamiya site or the TQ racing site any references to what the toe angle differences are between say the 1A-1XA and the 1B-1XB? Does anyone have a link to a chart or a page that gives these angles? Also the one piece block the car came with is 1C so I'm assuming if I wanted the same toe angle I would buy the 1C-1XC separate mounts?
If I wanted to switch to an aluminum servo horn which is the best to use on the 417? I have a Savox SC-1258TG servo installed.
Thx, Jeff
Thx, Jeff
