Like Tree4Likes
Tamiya TRF417
Old 10-11-2012, 07:28 AM
  #4006
What is the difference on the new motor mount?
scoyle is offline
Old 10-11-2012, 09:17 AM
  #4007
My friend told me that it is lighter. Although it may be because it doesn't include the centre brace that is missing (he was told by a Tamiya rep at the model show).
Qatmix is offline
Old 10-11-2012, 10:33 AM
  #4008
I wonder if these alignment pins are new? Not clear from looking at the mount itself, but more clear on the the bottom of the chassis.
napoleon1981 is offline
Old 10-11-2012, 10:38 AM
  #4009
artwork's Avatar
Trader Rating: 88 (100%+)
I wonder why the design has moved to Aeration shocks vs Bladder shocks. In what conditions do each type of shock excel? Anyone know?
artwork is offline
Old 10-11-2012, 11:20 AM
  #4010
CristianTabush's Avatar
Honestly, it is part gimmick, part necessity for the worlds.
Typically it is claimed that Emulsion (aeration) shocks promote more traction and handle bumps better.
However, In all the experiments that I did running on-road and offroad, I found the most grip and best bump handling came from soft bladders and drilled shock caps. In the past, when we used to not drill shock caps, then emulsion shocks were better.
I read in several places that Jilles used them for increased traction, since they ran no additives, this probably is the explanation.
Now why is Tamiya offering it like this? It's just the way they have always done it from what I remember. It seems that every so often, when they release their cars, they are replicas that commemorate some big event win. Last big one was the Worlds and this car is equipped with what JG ran. Next version, they might go back to bladders, who knows.
CristianTabush is offline
Old 10-11-2012, 12:47 PM
  #4011
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Ct- u should have seen the factory yokomos at iic. When grip was low they ran emulsion shocks and where killing it...
hanulec is offline
Old 10-11-2012, 12:52 PM
  #4012
Good to know Mike. I have been playing with it a bit, but our tracks have too much grip to see a benefit my rsd6 actuallyvhas too much grip most of the time
Old 10-11-2012, 04:55 PM
  #4013
Thumbs up
Originally Posted by kentech
http://kentech.blogs.se/ and http://www.tamiya.com/japan/hobbysho...port/news1.htm for first actual pictures on the TRF417 V5 Premium Package...
In the pic it looks like the wheels are offset +2 or +4 mm. correct me if I'm wrong. Very nice looking car!
Obsidian is offline
Old 10-11-2012, 09:17 PM
  #4014
Nuno Gancho's Avatar
Hi All,
What do you mean by emulsion shocks? Having a hole in the top cap?
Thanks.
Nuno Gancho is offline
Old 10-11-2012, 10:11 PM
  #4015
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Nuno Gancho
Hi All,
Thanks.
The attached picture is from the TRF201 buggy. Although the parts may well be different, I think the basic design concepts will be very similar.
PDR is offline
Old 10-11-2012, 10:19 PM
  #4016
Cpt.America's Avatar
Trader Rating: 52 (100%+)
can anybody reference the part numbers for the seperate suspension mounts for both the front and rear of the 417?
Cpt.America is offline
Old 10-11-2012, 10:25 PM
  #4017
PDR
PDR's Avatar
From Craig's blog site (http://tchub.wordpress.com):
54171 Separate Sus Mounts 1X
54172 Separate Sus Mounts 1XA/1A
54173 Separate Sus Mounts 1XB/1B
54174 Separate Sus Mounts 1XC/1C
54175 Separate Sus Mounts 1XD/1D
PDR is offline
Old 10-11-2012, 10:54 PM
  #4018
do you know which are the the same track and toe as the stock 1 pieces for front and back?
Old 10-12-2012, 12:50 AM
  #4019
VooDooPH's Avatar
Trader Rating: 18 (100%+)
same number/letter means the same width as the 1-piece units with the same number/letter...
i.e. 1C is 1C regardless if its with the one-piece or separate blocks.
VooDooPH is offline
Old 10-12-2012, 12:54 AM
  #4020
PDR
PDR's Avatar
It's in the manual, or you simply look at your car
The 417X manual says 1XA for the rear-front, 1C for the front-rear, so that would mean 54172 & 54174 respectively. Note that the split mounts are 2-in-1 (except for the 1X ones).
Various TRF team setup sheets use different blocks. In boosted 17.5, I run 1 degree less rear toe...
PDR is offline
