Team Associated TC6 Thread >
Like Tree20Likes
Old 12-18-2014, 08:41 AM
  #10186
Originally Posted by billdelong
yes, lift it out of the bulkhead, rotate it, then re-insert the bearing holder so that each notch is in the same slot on both sides of the bulk head. Keep increasing one slot at a time until you reach the desired tension. With the TC6... I think the grooves are inside the plastic bearing holder itself... same concept with XRay.
ahh so pry the bottom bearing holder off and then rotate and re-insert?? will give it a shot tomorrow..thanks for the info
omaharich68 is offline
Old 12-18-2014, 10:11 AM
  #10187
RussF's Avatar
Trader Rating: 22 (100%+)
Originally Posted by omaharich68
thanks for the info...the bearing holder looks like it is 2 piece? do i rotate like a ratchet (like with a little force)..or simply rotate it and reinstall the bulk head? I took it apart yesterday and it just seems like it wants to lift out of the bearing holder and only fits in there one oblong way...lol sorry i told you i was a newb..
You could also download the TC6.1 manual. http://www.teamassociated.com/manuals/TC6.1/
It shows how to adjust the tension of the belts in detail. I find myself looking at it everytime I need to adjust it. I can never remember what way does what. While you are at it make sure the "teeth" are clean on the diffs. Mine get carpet and sauce gunk caked in them from time to time and round out the slots making the belt easier to slip. You may want to invest in new belts if yours are worn. At least have a spare set.
RussF is offline
Old 12-18-2014, 12:21 PM
  #10188
awesome..thanks..do you take it apart all the way down to the bare diffs or do you leave in the CVD's and lift it part way out?
Old 12-18-2014, 04:37 PM
  #10189
RussF's Avatar
Ya I usually take out the top bearing cap screws and lift off the bearing caps without removing the camber links. Then I pop out the diffs, take the belts off, clean the teeth, then adjust the cam holders one or two teeth at a time looser or tighter depending on what I need. Make sure the left mirrors the right and reinstall.
RussF is offline
Old 12-19-2014, 07:55 AM
  #10190
ViperZ's Avatar
Hopefully I get to try the TC6.1 this weekend with the servo saver loctied the crap out of and settled for 2 weeks now.
I did receive my Yodog's Floating Servo Mount kit, however haven't begun to plan or settle into the required installation, yet.
ViperZ is offline
Old 12-19-2014, 10:00 AM
  #10191
YoDog's Avatar
Trader Rating: 28 (100%+)
I thought I'd mention that the servo mount requires 1 of each of these AE parts to complete the install.
1 AE# 3983 ball stud to replace the button head screw on the Ackerman adjuster plate.
1 AE# 7499 ball cup to lengthen the servo link.
A servo saver is optional as this method bypasses the stock saver.
YoDog is offline
Old 12-19-2014, 12:19 PM
  #10192
ViperZ's Avatar
You did mention it already Rick, thanks! This time however you included part numbers, so that's even better I meant I just have not accessed or scoped it out to the car.
ViperZ is offline
Old 12-19-2014, 01:32 PM
  #10193
YoDog's Avatar
Nice picture by the way!
Someone else asked about the additional parts which led me to look up the P/N's.
Hopefully others see this post and the question will be answered already.
YoDog is offline
Old 12-20-2014, 07:02 AM
  #10194
ViperZ's Avatar
Thanks! I'm looking forward to this conversion. I've ordered up the parts required as well as an X Ray servo saver.
ViperZ is offline
Old 12-20-2014, 10:34 AM
  #10195
hairy's Avatar
What do the numbers represent on the shaft of the turnbuckle eyelet that goes on the shock shaft?
hairy is offline
Old 12-20-2014, 10:34 PM
  #10196
AE-Reedy
They are just mold cavity numbers.
Sean Cochran is offline
Old 12-21-2014, 12:49 PM
  #10197
wtcc's Avatar
Today I finished my 6.1 conversion. I optimized the shock length, put on the old yellow and purple AE foam springs and finished the Protoform 905 body. It was again a lot of fun to work with the 6.1 chassis. With little effort and only minor problems it is adaptable to a lot of ideas.
I love the look of this beast
wtcc is offline
Old 12-21-2014, 02:10 PM
  #10198
Goof's Avatar
Trader Rating: 81 (99%+)
Default Servo saver undone
Hi guys I got into carpet to keep my racing going In tell off road . I'm racing 12r5.2 and tc6 in my tc the tc servo keep coming on done like Iv read here now does this floating servo parts help or only floats the servo off the chassis ?
Goof is offline
Old 12-21-2014, 02:22 PM
  #10199
ViperZ's Avatar
What? That body can fit on a 1/10 TC chassis? I take it will fit a WGT chassis then? I love the look of it!!
ViperZ is offline
Old 12-22-2014, 05:19 PM
  #10200
BulletMan's Avatar
I could use a little help with my setup...
TC6.1W.... lowered shock towers and WC top plate
I am have a really hard time getting the rear of the car planted... it really wants to over rotate from mid comer to exit.
i attached my setup from our club race yesterday.
WHAT THE Hxxx? my PDF is too big to upload! i need help on the too please.
BulletMan is offline
