Team Associated TC6 Thread >
Like Tree20Likes
Old 01-06-2014, 12:45 PM
  #9916
rc car guy's Avatar
read the last two pages...
rc car guy is offline
Old 01-06-2014, 03:21 PM
  #9917
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by lee111m
I did raise it. the belt seems to be decently tight. Haven't had an onroad belt drive so I'll probably have the guys at the track give it a once over next time I go. Thanks for the help guys.
I took a closer look and if the front belt is too tight, it will rub on the top deck especially if the diff is low in the bulkheads.
YoDog is offline
Old 01-06-2014, 03:25 PM
  #9918
YoDog's Avatar
Originally Posted by flag72
well I got my TC 6.1 car and its in great shape ( bought use).this will serve as a VTA racer how well will the front Spool work in VTA.or should I look for a front DIFF...
thanks
Danny
Hi Danny, you should have both on hand for different setup choices. Either will work fine but the diff will turn better and smoother in lower power setups. The spool will give better on power grip and feel for higher power motors.
YoDog is offline
Old 01-06-2014, 07:48 PM
  #9919
Trader Rating: 18 (100%+)
thanks YoDog
flag72 is offline
Old 01-12-2014, 10:53 AM
  #9920
Suspended
Trader Rating: 86 (100%+)
got some tc6 parts for sale
http://www.rctech.net/forum/r-c-item...l#post12898559
littlealex is offline
Old 01-16-2014, 03:19 PM
  #9921
shanwright's Avatar
Trader Rating: 25 (100%+)
Thumbs up Yokomo dif in TC6
Hi guys,
I got a second hand car a while back in got a number of yokomo diffs with it.
I went to install one the other day and I found the hole in the out drive is smaller then the std associated one 6.15 not 6.35 (1/4). The ball on the end of the axle binds up. My question is ?
Is this a typical problem with these diffs. Or are there different out drive cups from yokomo.
What do you guys do to fix it?
I was just going to drill them out to 1/4. But the hard anodizing will be removed..
I do have a few associated diffs so I rebuilt one of them for now.
Steve
shanwright is offline
Old 01-16-2014, 04:10 PM
  #9922
rc car guy's Avatar
are you talking about the out drive where the cva goes into the diff? the only screw that is on the outside of the SPOOL is the one it attaches to the spool out drive with the spool itself, slightly confused at what you asked with the terminology you described it with
Old 01-16-2014, 06:11 PM
  #9923
shanwright's Avatar
yes to the first question.
Screw?
Im talkin about a rear diff.
Yokomo Brand.
axle to Diff interface.
Axle binds in drive cup.
ID of drive cup is smaller them Standard TA style.
Simple fix drill out cup from 6.15MM to 6.35mm (or 1/4")
I just wondered if this was typical?
or do Yokomo make other drive cups for a TC6?
I will just drill them out but it will remove the coating.
Steve H
Old 01-16-2014, 07:11 PM
  #9924
rc car guy's Avatar
Screw?
Yokomo Brand.
Steve H
I belivw that the yokomo brand doesnt use the the cva bones so maybe try without it ?
Old 01-16-2014, 07:30 PM
  #9925
YoDog's Avatar
Hi guys,
Steve
This is the same problem we had with the original spec-R gear diff out drives. While machining or drilling them will remove the anodizing, the universals use a plastic blade where contact is made so wear will be minimal. If you have the Associated gear diff, just use them instead.
YoDog is offline
Old 01-16-2014, 07:55 PM
  #9926
shanwright's Avatar
Thumbs up All sorted thanks
Yes you right the inside is not a wear surface, I just tried drilling one out and it works fine very simple fix. I was thinking I would need to strip the diff and put them up in the lath but. Drill press worked fine, only need a small skim cut. I polished them with some 800 grit in the dremel flapper and look like bought one.
I've got 6 brand new ones with all different weight oils in them and only two Associated so I thought I would get them sorted so I could use them. Anyway all good now.
Thanks guys
Old 01-16-2014, 11:05 PM
  #9927
jpx
jpx's Avatar
Drilling like you did is what I heard people did before the AE-diff was available. So it should work fine an wear will not be a problem due to drilling.
Jan-Peter
jpx is offline
Old 01-18-2014, 07:52 PM
  #9928
Trader Rating: 1 (60%+)
Does anyone have the part numbers to convert my Tc6.1 to worlds car. Also does anyone have these parts for sale along with world's main chassis
racer034life is offline
Old 01-18-2014, 08:54 PM
  #9929
rc car guy's Avatar
Its the shock towers and bearing caps along with the chassis thats all ae has this info under 6.1
Old 01-18-2014, 09:36 PM
  #9930
Yes i remember seeing the post on here. But i havent been able to find the post where someone had posted the part numbers for everything.
