Team Associated TC6 Thread >
Like Tree20Likes
Old 12-06-2012, 08:36 AM
  #8236
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Scottmisfits
It would have to be one hard impact, or the screws come loose.
One solution might be to put a set screw in the blocks to touch the hinge pin. This might keep them from rolling on impact and/or the screw coming loose. The hinge pin is long enought that it shouldn't be able to fall out unless those blocks roll a long way. Maybe they are worn out to much and you just need new blocks. I have never experienced this or heard of theis problem until now so I am just trying to think of options.
I actually struggled with this myself early on when I first got the TC6 a couple of yeas ago. Sure, I hit more stuff than I do now but those plastic shim are too soft and compress very easily. I went so far as to buy a set of the "dial a grip" blocks which did stay in place but I found them a little too complicated. The new TC6.1 offset blocks are much better though.
YoDog is offline
Old 12-06-2012, 08:39 AM
  #8237
YoDog's Avatar
Originally Posted by IndyHobbies.com
I should have clarified...that's NOT a photo of my car. That's just one I grabbed off the Associated website showing the arm mounts. Sorry about that!
My car is not set up the same as the photo. I'm using the "0" mounts with shims.
That makes sense...
Still, the shims reduce the contact area and lend themselves to rotation.
YoDog is offline
  #8238
Scottmisfits's Avatar
For the plastic shims, ditch them and use the 1/12 scale front ride height shims for the 12R5 series of cars. They're a nice wide washer and come in a few thicknesses. I've done that since almost day one with my TC5, TC5R, TC6, and TC6.1.
Scottmisfits is offline
Old 12-06-2012, 08:41 AM
  #8239
YoDog's Avatar
+1
YoDog is offline
Old 12-06-2012, 09:27 AM
  #8240
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
My son and I are running our TC6 in USGT. We are very happy with the way it drives. The only continous problem we have are the front arm mounts. Most of the time, if we hit anything, even lightly, the front axle pulls out of the arm mounts. Usually ruining the mounting hole so that the mount has to be replaced.
It doesn't seem to happen on my TC5 as much.
Do you guys experience the same thing with your TC6's? Is there something I can do to help prevent that from happening? Its a cheap fix, so I'd rather have that happen then the arm break or worse, but it just pulls out too easy it seems.
I have never had any backing out issues. I did however used a super long screw if you look at the bulkheads and its been a year and no backing out. I just added the rsd blocks just for giggles even though I never had the holders swing out like you mentioned. I may end up taking them off since im anal about extra weight when running brushed motor.
You can also put a 5-40 nut on the inside and they will never come off
Mr.juarez is offline
Old 12-06-2012, 09:34 AM
  #8241
I use the plastic shims from the kit on all my mounts and have not had a mount rotate on me. I do use threadlock on all the screws, which I think may be the reason I haven't had any problems.
jha07 is offline
Old 12-06-2012, 10:16 AM
  #8242
kewdawg's Avatar
Do you have the part number?
kewdawg is offline
Old 12-06-2012, 10:22 AM
  #8243
http://teamassociated.com/parts/details/4617/
Old 12-06-2012, 10:30 AM
  #8244
kewdawg's Avatar
Default That was quick!
Thanks!
kewdawg is offline
Old 12-06-2012, 10:35 AM
  #8245
No problem. Keep in mind that these aren't exactly the same thickness that the plastic ones are, but they are close. Another big benefit to these is that they are repeatable because they don't compress like the plastic ones.
Old 12-06-2012, 11:01 AM
  #8246
IndyHobbies.com's Avatar
Man, I love these forums! Where else can you get good advice from multiple people who really know what you are talking about and have solved it themselves? Even at the hobby shop you often just get the advice of one person. At the track we are always too busy to do much talking.
IndyHobbies.com is offline
Old 12-06-2012, 11:40 AM
  #8247
kewdawg's Avatar
Right! Thnx , again.
Is it me or is that hair piece looking ridiculous on ol' Chuck?!
kewdawg is offline
Old 12-06-2012, 02:42 PM
  #8248
mtbboy's Avatar
You should probably walk up to him and say that
mtbboy is offline
Old 12-06-2012, 03:06 PM
  #8249
kewdawg's Avatar
He's too old, now. He's like 70! Don't be fooled by Tv. He only plays an unbeatable tough guy. Plus, he would need an attorney after trying anything remotely physical.
kewdawg is offline
Old 12-06-2012, 03:16 PM
  #8250
Mr.juarez's Avatar
Have you seen the video of the old white guy beating the crap out of that black guy in frisco? Dont let age fool you
