Team Associated TC6 Thread >
Like Tree20Likes
Old 07-20-2012, 01:23 PM
  #7156
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by whiteflagwar
Anyone running the one-way spool? I'm running on high grip carpet and could use a little more steering while on the brakes, do you guys think it's worth trying?
The one way is really only useful on large flowing tracks. Carpet track are typically small and technical. If you need more steering under braking, try a diff up front and make adjustments in your set up to get more weight transfer to the front. ie, more droop in the rear or slightly stiffer rear springs. There are plenty of adjustment on these cars to get it where you want it. It's all about weight transfer.
A little toe out in the front can help with initial turn in as well.
YoDog is offline
Old 07-20-2012, 04:51 PM
  #7157
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Rockin G
Which holes are you trying to hit? I have mine in the forward hole and the bottom hole. I dont remember if that location raises the motor up a bit or not. Our 27T class uses the Axial 27T as the spec motor. I am not sure if there is a size difference in the shaft bushing.
The motor only has 2 holes for te motor mount screws. They don't line up either needs to drop about 1mm lower which is why I grinded the motor mount oval part down so it lowers the motor, but I tried spacing the bushing hump out of the mount but it puts the motor 1 inch hanging out pass te chassis edge and it leaves the motor shaft short to reach the spur. So I flipped the pinion and put the set screw neck towards the motor side and now the pinion neck hits the motor mount like the motor did before. The motor is a 27t tamiya silver can.
Originally Posted by YoDog
I'll be at the track tonight and I'll be happy to help out.
Using 2 screws is probably the way to go and I'd have to say that you will want to use a smaller spur gear to get the right spacing. What FDR is suggested?
We can always come up with a different combination that will both fit and give you the FDR you are looking for.
I have a bunch of 48 pitch stuff so I think we can find the right combo.
Thanks for the offer but I won't go race. Last time I got there and had to do some wrenching it was not fun in a 105 temp pitting on a 120 pavement. I just got really frustrated that I blew like 400 to run gt3 and didn't even make it, have fun there
Thanks for the offer maybe next time
Oh I was told to run 4-4.3 in 17.5 and brushed motor in the 5.6
Some tell me to run 5.5 in 17.5 and other 3.8 Yada Yada I don't know which one to listen to as one tells me he's bsing me and the other one does as well.
Mr.juarez is offline
Old 07-20-2012, 05:59 PM
  #7158
bird_house's Avatar
That's a girl's car. You might try bigger bumpers on the 6.2
bird_house is offline
Old 07-20-2012, 06:24 PM
  #7159
evochick's Avatar
Yep, it must be why i drive one
That would have to be the lamest post in history.
Beth.
evochick is offline
Old 07-20-2012, 06:54 PM
  #7160
Mr.juarez's Avatar
Beth.
Troll...
Old 07-21-2012, 09:37 AM
  #7161
vito's Avatar
ok whats the low trun i can go in this kit i just play and like a novak 540 ones
vito is offline
Old 07-21-2012, 11:07 AM
  #7162
sosidge's Avatar
The mounting hole centres should be the same on the silvercan as on a brushless motor. It should screw into the same slots as normal.
The problem is the oversized front bushing on the silvercan.
What you can do is dremel the motor mount to make the hole for the bushing bigger. Better still, find someone with a mill to do the job more precisely.
sosidge is offline
Old 07-23-2012, 03:47 PM
  #7163
Originally Posted by racer x 1
Cant wait to get my hands on that!
Let us know how it goes with it!
http://www.speedtechrc.com/store/ebp...=1083&id=12900
Have a few more in stock and more on the way
stitchy is offline
Old 07-23-2012, 05:39 PM
  #7164
racer x 1's Avatar
Trader Rating: 27 (100%+)
For those that were wondering the tek 6 is beautifullll. LoL i will begin converting in T minus 3 hours i just picked up 2/10 of sexyness.
racer x 1 is offline
Old 07-24-2012, 04:28 AM
  #7165
Chaz955i's Avatar
Ok, you have asked the same question several times already. Put whatever the lowest TURN motor Novak makes in your car and go have fun.
Also, this thread is about the TC-6. If you have specific questions about motors or electronics there are other threads dedicated to those subjects where you might be able to get a quicker answer. Good luck.
Chaz955i is offline
Old 07-24-2012, 04:48 AM
  #7166
Who's surly now?
mackin is offline
Old 07-24-2012, 05:01 AM
  #7167
Chaz955i's Avatar
Originally Posted by mackin
Who's surly now?
I learned it from you.
Nice maiden voyage with the 6.1 Saturday. First run and a win. Can't get better than that.
Chaz955i is offline
Old 07-24-2012, 05:23 AM
  #7168
jhautz's Avatar
Trader Rating: 86 (100%+)
4.5
jhautz is offline
Old 07-24-2012, 08:21 AM
  #7169
1mrdad's Avatar
Trader Rating: 48 (100%+)
Originally Posted by nitrous36
Im going to be running 17.5 blinky(no boost/no timing). After building the kit and looking at the gearing chart(in the book), it was clear this car was intended for modified motors. And after reading the gear chart its clear I cant and want be using the 87t spur that came in the kit with a 175.5 motor.
I searched online, read the charts and did the math. I cant believe the 17.5(w/timing) needs a gearing so high. So now Im debating if I should get a 72, 75, or 77 spur. That would allow me to gear the motor for 3.5-4.0
On a smooth paved 220x125 asphalt race track in 17.5 blinky class, I have my FDR at 3.19 (64pitch gears). That's with a Revtech 17.5 (12.5 HT rotor), timing on the motor 1 mark before max, high speed fan, temps in the lower 140* on 95* day.
1mrdad is offline
Old 07-24-2012, 08:32 AM
  #7170
vito's Avatar
Originally Posted by jhautz
4.5
i was thinking 4.5 trun. how fast will it be on top end?
vito is offline
