Team Associated TC6 Thread
#6466
They used to be a difficult bearing to find as it was not a standard size.
#6467
does good charger and battery help on performance? and also did a good charger really help to keep more life for a battery ( for good battery and normal cheap battery ). let say i've a turnigy nano-tech 6000mah 65-130c 2s battery, how many A should i go on it? because normally i only put at 4.0A to charge it.
next question, i need help on tuning/adjust a car tweak, hope can explain in more simple way to me. thanks.
#6468
You are safe when you charge with 1C, which is for 6000mAh 6A. With 4A you are safe too, but charging just takes longer.
#6469
Guest
#6470
Olly Jefferies setup
Just wondering if anyone has tried Olly Jefferies setup and what are their thoughts. I have made a few of the changes from stock setup to Olly Jefferies setup and have had good results. The setup is the closest I can find to suit the track I race at, it is a low to medium grip outdoor asphalt.
#6471
With your battery, you should be able to charge at a 6A rate at least.
The way LiPo charging works, no charger should be able to give an advantage. But what does differ between chargers is the maximum charge voltage. Many chargers will only charge a battery to 8.35V (even if the screen shows differently). So if the maximum allowed voltage under the rules is higher than this (which all are), you are giving up some performance.
A charger with an adjustable voltage cutoff or what is sometimes called "voltage calibration" allows the user to fine tune the voltage cutoff so that the final voltage will match what is allowable under the rules. I know the LRP Pulsar 3 and Pulsar touch have this feature. Some other high-end chargers might as well but I don't know them off the top of my head.
#6472
#6473
Sorry. My bad.
#6474
I'm having a hard time finding more of the batteries we were running last year in our TC6's. There are many other brands and options available out there to be found, but I'm having a hard time finding packs that are the same weight as the handful we have left. I did manage to find some packs that are three grams lighter than the packs we have left, so my question...
Just HOW much of a difference would three grams make in balance and setup? We have two cars, and enough packs to run one brand in one car and the other in the second.. but to help keep my sanity this summer it would be much simpler to have them be mix and match. I know I could add weight to the new packs, but I'd prefer not to if need be because we also run them in our offroad vehicles and weights would just get in the way there. My other half runs onroad with me, so anything that simplifies things is helpful.
#6475
#6476
Am I just to the point where it's reasonably well balanced and I can stop fiddling with this, or is there a better/simpler method to this? If it were that far out of whack, it would of course lean the same way every time - and it doesn't. Still in bench racing mode until outdoor Sunday racing starts, is it summer yet?
#6477
3 grams is the difference between my two Reedy LiPos which have the same item number.
Really, up to 10 grams per side weight difference are hardly noticeable...
#6478
As long as things balance out relatively evenly, just drive the car. If you are super meticulous and OCD, you are going to need a 4 scale setup to cornerweight the car.
#6479
Suspended
Hey guys, Just bought a TC6.1. Im going to run it in my 25.5 VTA division at my local track. I was wondering what is a good Pinion/Spur setup for this car so I can get good punch and top speed. I want to run in the 3.7 to 3.5 FDR.
I had my T2 setup with a 96/43 (3.8) with 45 degree timing on the motor and it was very good. Wondering if I should try to keep it as close to that setup as I can with the TC6.1
I'd rather hear from guys that already have raced with the TC6.1 before I make a decision.
Thanks.
Thanks.
#6480
Setup
Thanks for the info Rick. Did you try the Olly Jefferies setup at the Tamiya USA Raceway? I am interested to see what your setup is like on my track.
