Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 08-30-2023 | 11:21 AM
  #12016
Originally Posted by slappomatt
how long do you normally get out of a set of spec tires?
Running on epoxy coated concrete with really good traction, I get between 15 and 20 five minute runs. Once I get the ring of death, the tires don't work very well.
LonnyJ1950 likes this.
glennhl is offline
Old 08-31-2023 | 10:41 AM
  #12017
The ring of death... I'm trying a slightly different setup on my car to see if the ring of death is caused by too much camber during full roll.
kn7671 and glennhl like this.
Sabin is offline
Old 08-31-2023 | 02:33 PM
  #12018
That's exactly what it is. The USGT tires don't flex a great deal, so the more your setup can keep those tires flatter and in full-contact with the surface, the longer they will last. On carpet, we usually run the camber at no more than 1-deg, and with the proper setup, should wear edge-to-edge instead of the inside edge developing the ring of death.
kn7671 is offline
Old 08-31-2023 | 02:37 PM
  #12019
With the correct setup and proper car and maintenance by ensuring they remain glued throughout their life, not factoring for surface, you should be able to get 30-50 runs out of them.
kn7671 is offline
Old 08-31-2023 | 07:28 PM
  #12020
New compound only lasts 5 race days on asphalt and the last two race days the tires are getting bad already. No ring of death due to 1 degree camber but the outside shoulder starting to round off from rolling. Also with summer heat the tire surface gets sort of wrinkly.
approximately 20 runs.
glennhl likes this.
Xrayray is offline
Old 09-01-2023 | 10:34 AM
  #12021
Which will help the belted tyres significantly, once we crack the question of which traction compound works the best with that new rubber formulation.
Sabin is offline
Old 09-06-2023 | 04:53 PM
  #12022
Hi guys,
Total newbie here to on road racing. I race rc boats now but looking to race the USGT series during my down time. Any suggestions on what car i should go with? Went to the local track and seems to be a mixture there. Any suggestions or tips you guys have would be appreciated.
Thanks, Kurt
kurt27 is offline
Old 09-07-2023 | 02:34 AM
  #12023
gigaplex's Avatar
Originally Posted by kurt27
Hi guys,
Thanks, Kurt
Try to figure out who at your track looks the most helpful, and then get the same car as them.
gigaplex is offline
Old 09-07-2023 | 07:07 AM
  #12024
thirtydaZe's Avatar
Hi guys,
Thanks, Kurt
What was the mixture comprised of? We can help based on that.
MonkeyCmonkeyDo likes this.
thirtydaZe is offline
Old 09-07-2023 | 09:25 AM
  #12025
Thanks for the help here guys.
They had Xray's, Serpents, ARC, and Xpress. Maybe some others I could have missed I am not sure on the models though.
kurt27 is offline
Old 09-07-2023 | 09:40 AM
  #12026
thirtydaZe's Avatar
I'd consider xray personally.
Old 09-07-2023 | 08:47 PM
  #12027
whatever you can get parts for. they're all the same.
slappomatt is offline
Old 09-08-2023 | 07:16 AM
  #12028
Thanks for the tips guys
kurt27 is offline
Old 09-12-2023 | 09:49 AM
  #12029
I just got back in to carpet racing within the past year and went with Xray. You cant beat their manual for setup information and explanations, plus there are a whole treasure trove of videos on YouTube for the cars. They are expensive, but if you go the used route instead of the latest and greatest you can save quite a bit. I run 2021 T4's and have learned so much from the guys who used to race them and watching Alexander Hagberg's videos.
simple likes this.
Greg Holford is offline
Old 09-12-2023 | 04:57 PM
  #12030
Thank you, Greg.
Greg Holford likes this.
kurt27 is offline
