Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 07-12-2023 | 10:49 PM
  #11896
DARKSIDE's Avatar
Holy Smokey Robinson... yall will F Up a class ... I cant believe I took the time to read all this at 1230am ... I would love to see all this on the track and make a difference to anybody but a "pro" driver... come on guys yall killing it... can we just work on setup and running the motors as they were intended ?... I have one of the original 5 motors and it still works just fine,, with the right FDR and setup Im right there in the mix or on top of the pile.
Lets just race and have some fun... put some mirrors and headlights in your GT car and feel the fun
DARKSIDE is offline
Old 07-12-2023 | 10:58 PM
  #11897
Originally Posted by Sabin
...how do you prevent a racer from modifying the ESC's internals or programming without stripping it down to the circuit board and attaching a logic analyzer or code inspector? Are we going to enlist the service of scrutineers now?
Simple. All spec ESC's will have a security sticker placed across the two halves of the case and motors will have a security sticker placed across the endbell and can. When the sticker is removed it will leave parts of it behind. Tires, inserts, and wheels will be a little more difficult, but one way is to measure the firmness, if the firmness of the tire meets specs, then there shouldn't be a tire advantage. If it were up to me, I'd only allow one ESC to make things easy. I think the Hobbywing Stock Spec is a suitable ESC for USGT and it's inexpensive, which is in the spirit of Spec Racing. If scrutineers are what's needed to keep things fair and people from cheating then yes, but obviously this will not be a common practice at the club level, because at the end of the day it's up to the Race Director as to how their program is run. Personally, I would only tech the top 3 cars at big club races, regionals, and nationals. I am in no way suggesting that people will have to buy new Motors and ESC's, that is something that will slowly be phased in, so for the time being I would suggest that when a car goes through initial tech inspection before an event some type of sticker be placed over the places I already mentioned, if the racer chooses to leave the sticker on it will speed up pre and post tech.
I wrote that rule so it encompasses every class that a sanctioning body may cover. The USGT class does not have a spec chassis, so that part of the rule would not apply to USGT. The only things spec in USGT are ESC, Motor, and Tire, everything else is fair game.
rcuser007 is offline
Old 07-13-2023 | 12:59 AM
  #11898
gigaplex's Avatar
but how do you prevent a racer from modifying the ESC's internals or programming without stripping it down to the circuit board and attaching a logic analyzer or code inspector? Are we going to enlist the service of scrutineers now?
How is this a USGT specific problem? That applies to any blinky class.
gigaplex is offline
Old 07-13-2023 | 01:14 AM
  #11899
gigaplex's Avatar
Security stickers are pretty easy to defeat. What you described is neither simple nor effective.
gigaplex is offline
Old 07-13-2023 | 07:23 AM
  #11900
Raman's Avatar
New work of art from PF, the Venturi. I love the back, it reminds me of absolutely nothing
https://www.racepf.com/touring-car-1...PhicbUag9Ov_-k
Bsthetech likes this.
Raman is offline
Old 07-13-2023 | 07:30 AM
  #11901
nitrous36's Avatar
Moderator
I think you highlighted the even bigger problem, that people would try to defeat them in the first place.
nitrous36 is offline
Old 07-13-2023 | 08:20 AM
  #11902
The problem with stickers is the adhesive softens with heat, and when it gets hot enough, it falls off. The best solution that I can think of is packaging the USGT motor in a 2-in-1, like the hobbywing axe system, measuring no-load amp draw to see if it matches a predetermined figure, using nail polish to color the screws and using that for a handout motor.
Sabin is offline
Old 07-13-2023 | 08:48 AM
  #11903
OffRoadJunkie's Avatar
If the rule makers wanted to truly put an end to all the nonsense while making things easier on themselves, race directors, racers, and newcomers, the following rule would be added; Any alteration of any kind to any part, motor, tire, esc, servo, body, wing, and/or chassis determined to be spec is forbidden, no exceptions. If found to be violating this rule you will be automatically DQ'd, furthermore if found violating this rule at a sanctioned regional or national event you will be suspended from participating in any and all future sanctioned events.
The problem with this is, from what I have seen, most of the cheaters are really good friends/associates of the track owner. Also, There would have to be a BOLO for this cheater at every track. Otherwise, they may be suspended at one track, but they would just go to the next track until their suspension is up.
There is nothing that can be done to prevent cheaters. Although they are the most childish and immature people in the RC world, they will keep doing it because they think it makes their tiny winky bigger. Some racers just like the thought of being a rebel by beating the system and winning. If that is the case, maybe there should be a class for that one. A 21.5 class where you have to use all stock spec, blinky, and fixed timing electronics. However, you can modify it all you want but it can't look like it was modified.
Mac The Knife likes this.
OffRoadJunkie is offline
  #11904
Thank you for adding to the conversation, I didn't think about the heat. Colored screws would be an easy way to tech the motor and regarding the esc I'm sure some type of seal could be figured out. It's astonishing the lengths that some people go to cheat in this hobby and if stickers were implemented no doubt some would've tried to replicate a sticker that would've only been made available to officials and race directors and I'm sure some race directors would've given them to their favorite racer(s), but I think most would've played by the rules.
The motor/esc combo is a good idea that I personally don't prefer due to electronics be crammed in to a small enclosure next to a heat source, but at the same time it makes things that much easier and it cuts costs.
USGT is a blinky class is it not and it's not a problem specific to USGT, so those classes would need to be teched as well. Again the rule I wrote is a global rule, it applies to all classes but all specifics may not apply to every class. People have stated that well I do this and that because there is no rule preventing it, the rule I wrote takes care of that.
None of this would be an issue and all of these rules wouldn't have to be made if people were able to race classes as intended, but nope, people just can't let things be. Remember it's you that chose to race a spec class, there are other classes that you can tinker to your hearts delight, go race in that class.
Old 07-13-2023 | 11:07 AM
  #11905
Which is why I was suggesting a GT1 type class (doesn't *have* to be called GT1) where you can run boosted/turbo esc and slicks while running the GT bodies.
Sabin is offline
Old 07-13-2023 | 11:23 AM
  #11906
Kregger's Avatar
What car is this based off of
​​​​because if you read the description its sounds like its not based off anything
Kregger is offline
Old 07-13-2023 | 11:44 AM
  #11907
mrreet2001's Avatar
R/C Tech Elite Member
Im thinking Lotus Evija
https://www.lotuscars.com/en-US/evija
glennhl likes this.
mrreet2001 is offline
Old 07-13-2023 | 01:10 PM
  #11908
robk's Avatar
Originally Posted by mrreet2001
Correct
robk is offline
Old 07-13-2023 | 01:28 PM
  #11909
Suspended
The solution to no tampering with the ESC or Motor is Liquid Contact Indicators (LCI). Simply add the fluid to the indicator itself, put on the inside, and if you try to open the motor, it turns blue ( or what ever color the manufacturer wants). Comes attached on the inside from the factory, no way around setting it off if you try to open either. You could add indicator strips for easy visual verification at races.
However, many different things are killing USGT, and RC racing in general. Creating tamper free parts won't fix that.
But it is hella entertaining to read.
Metalsoft is offline
Old 07-13-2023 | 02:25 PM
  #11910
Why stop at changing colors for tampering. The esc should just stop working and need to be replaced: buy another esc or stop cheating...lol...
bertrandsv87 is offline
