Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-13-2022 | 11:18 PM
  #11221
Originally Posted by Robio
What is a good starting FDR for the Gravity Spec motor. Running it for the first time on Parking Lot Asphalt. Fairly open track layout with 80-90' Backstraight.
Rob...
Rob, is it for Santee? Try gearing up a half point and maybe keep going up. Topher may have a better answer for you tho...
Robio likes this.
Xrayray is offline
Old 05-14-2022 | 06:58 AM
  #11222
2.9fdr to 3.10 fdr on 100ft straight tracks, depending on infield smoothness....
bertottius likes this.
bertrandsv87 is offline
Old 05-14-2022 | 09:13 AM
  #11223
Prefect. Thanks. I searched the thread and couldn't find much info. I know gearing is subjective but ballpark helps. I'm new to 21.5
Yes Ray, for Santee. Will you make it down?
Robio is offline
Old 05-15-2022 | 09:24 AM
  #11224
I am currently in 2 builds, might be a little bit before I can. I will be in 17.5 soon.
Xrayray is offline
Old 05-15-2022 | 11:53 AM
  #11225
Originally Posted by theproffesor
Sent a message to Paul to get the lowdown on the new rims. The old wheel is 7mm from face of wheel to hex, new wheel is 6.7. That’s it’s. It is only .3mm difference.
When can we expect to see the new rims/tyres?
Sabin is offline
Old 05-15-2022 | 09:06 PM
  #11226
theproffesor's Avatar
They are already out and what is available on his site. They are the 6 spoke rims.
theproffesor is offline
Old 05-16-2022 | 08:12 AM
  #11227
Yes, the last 4 sets of USGT tires I've bought have been the new 6 spoke rims. However, even though the new belted tires showed up at a national race recently they are not available to the public. I'm guessing Paul wants to use up his supply of non belted tires first to keep the hobby shops from having to eat a bunch of inventory.
glennhl is offline
Old 05-16-2022 | 08:34 AM
  #11228
Dan's Avatar
Dan
Will the non belted tires be completely phased out?
Dan is offline
Old 05-16-2022 | 09:42 AM
  #11229
mrreet2001's Avatar
R/C Tech Elite Member
Originally Posted by glennhl
Yes, the last 4 sets of USGT tires I've bought have been the new 6 spoke rims. However, even thought the new belted tires showed up at a national race recently they are not available to the public. I'm guessing Paul wants to use up his supply of non belted tires first to keep the hobby shops from having to eat a bunch of inventory.
I could be wrong, but as I understand it there were supply chain issues and Paul couldn't get enough of the regular tires for the event.
Rick Vessell likes this.
mrreet2001 is offline
Old 05-16-2022 | 10:40 AM
  #11230
What's the website? There's a lot going on here so it's hard to keep up.
Sabin is offline
Old 05-16-2022 | 11:03 AM
  #11231
mrreet2001's Avatar
https://www.teamgravityrc.com
Old 05-16-2022 | 11:20 AM
  #11232
Originally Posted by mrreet2001
Ah! okay. I suspected that was the one but I wasn't sure.
Sabin is offline
Old 05-20-2022 | 05:29 PM
  #11233
Went with the gearing advice I was given this past weekend. Started at 3.8, went down to 3.4. Temps were fine considering ambient was high 80's. Track temp around 120*ish. Couldn't get out of everyone's way fast enough! It wasn't horrible in the infield, but down the straight, which was shortened to about 50-60', it was laughable. Guess I could've gone lower on the fdr, but didn't seem worth the time to swap out the spur, as the pinion I used was large as I could go.
Am I missing something, or is that about all I'm gonna get out of the Spec motor?
On a positive note, the new chassis was fantastic!
Robio is offline
Old 05-20-2022 | 07:17 PM
  #11234
Rob, I could a told you it's weak and only good against other spec motors. I have a Motiv MC4 21.5 Dyno tuned if you want to try it out.
Xrayray is offline
Old 05-20-2022 | 08:09 PM
  #11235
Haha! Thats what I figured. No worries. the motor came with the car I got, so no great loss.
I appreciate the offer Ray. I have a new TCR 21.5 coming...
Robio is offline
