Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 08-07-2021 | 08:47 PM
  #10741
Kregger's Avatar
Originally Posted by bertrandsv87
I guess usgt racers will need to carry both types of 21.5t motors in their bags just in case....
Only if you travel to different tracks.
glennhl likes this.
Kregger is offline
Old 08-08-2021 | 03:31 PM
  #10742
robk's Avatar
Originally Posted by NutDriver
I am another who likes to mount my own USGT tires. I have bought some wheels from RC Mart that looked much like the wheels that Exotek made for a while (hint, hint Mike). I think they are made by Speedline.
I ordered a set of premounts from Monaco RC. They are tagged as Rides and came on a while split-five spoke wheel. They were listed as ETS approved. The wheel is very shiny white which makes me wonder if it will prove to be brittle. I haven't run them yet.
Scott
Check to see if they are belted - a good squeeze should probably show you. ETS is using a belted Ride USGT tire for FWD.
robk is offline
Old 08-08-2021 | 03:33 PM
  #10743
robk's Avatar
Originally Posted by Raman
I usually build my own USGT tyres and have frequently used Tamiya rims. The newer 24mm rims that are hard (54738, 54739) are pretty strong. The ones that are white abs on the other hand don't take knocks too well. Exceptions of the 5 star 53471.. they seem to do pretty good.
@ Mike - I was under the impression that MST are 26 mm?
Originally Posted by MikeR
I think being unbelted it would just concave the tire so that you'd drive on the sidewalls. Instead look into MST wheels (they seem like the new 'HPI' company). Really nice looking range of 24mm wheels. And also tried and true Tamiya spoked wheels.
Originally Posted by Soul Surfer
MikeR and Raman , thanks for the info. It seems like most of those options in +0 offset are out of stock everywhere online unfortunately. However I purchased a couple sets of 10 spoke wheels from Sweep Racing USA not too long ago. They are in stock and are very reasonably priced.
Maybe everyone who likes mounting their own tires should contact Proline. They had probably 5 -6 spoked 24mm wheels for sedan before dishes took over everything. If they still have the molds, maybe they could be convinced to make some.
Rick Vessell and NutDriver like this.
robk is offline
Old 08-08-2021 | 03:46 PM
  #10744
Thumbs up US Made Wheels!
I'm all for that! I looked on their site and all they have listed is contacts for sales and product support or their social media pages and I don't partake. Are there other options to reach the powers that be, Rob?
Soul Surfer is offline
Old 08-08-2021 | 05:05 PM
  #10745
Going to a 26 mm wheel flattens the tread surface a bit and can help combat tire swelling.
Tamiya and speed mind have the best options for race quality wheels. Some are even available in different offsets.
Premount wheels can be brittle and I only use them if they are handout races and am forced to use them.
HPI and may wheels look great but are not as tough as Tamiya and speed mind.
dman18t is offline
Old 08-09-2021 | 04:29 PM
  #10746
robk's Avatar
Hard to say other than the options you have mentioned, especially since Horizon has acquired Pro Line...
Rick Vessell likes this.
robk is offline
Old 08-10-2021 | 03:52 AM
  #10747
You could try reusing the rims from Jaco tires.
mooby64 is offline
Old 08-11-2021 | 07:42 AM
  #10748
Dan's Avatar
Dan
How is the Zoo Racing Bwoah on carpet?
Dan is offline
Old 08-11-2021 | 04:45 PM
  #10749
Ivan Dickson's Avatar
Works very well! lots of steering, awesome rotation, you made to turn down your steering.
Ivan Dickson is offline
Old 08-12-2021 | 11:28 AM
  #10750
Id leave the rules for USGT alone. It just works and gives everyone a fair equal playing field
Timken500 is offline
Old 08-16-2021 | 09:11 AM
  #10751
Default Wheels
if you want wheels contact Paul Lemieux and he sells the wheels on his gravity line at a reasonable cost . I have yet to break one of his wheels .
john holmes 69 is offline
Old 08-16-2021 | 10:50 AM
  #10752
Raman's Avatar
Which traction compound are you using at your tracks?
We made the switch from SXT to TDK (organic) last year. Both are good in regards to traction.
As for dire durability, the organic TDK is causing early swelling.. eg just when you’re tyres start to break in and grip comes up, swelling starts.. which for carpet is not so great for carpet.
I will add that I only use the same product for cleaning and saucing.. eg TDK for cleaning after race and TDK for saucing. Nothing else
Raman is offline
Old 08-16-2021 | 11:38 AM
  #10753
+1
I really like the 6 spoke wheels myself. If you count what's available from Gravity, Sweep Racing, Tamiya and Speed Mind I guess there are plenty of affordable options to choose from.
I was looking at TDK products the other day, but didn't know if anyone else had experience with them. Have you ever tried it on asphalt?
Old 08-16-2021 | 12:00 PM
  #10754
Raman's Avatar
My friend in Nor Cal runs it on Asphalt. As a sauce it’s works just as well as SXT. Issues I find with it are:
1. cold temperatures - the fatty oils in sauce harden and form fat particles. You need to warm up the sauce 😂
2. USGT / VTA spec tyres balloon much earlier than with SXT.
F1, TC tyres such as Sorex etc don’t have the swelling issue
Raman is offline
Old 08-16-2021 | 09:03 PM
  #10755
I've stopped cleaning with tire sauce and just spin the tires on a scotch pad after each race. Takes seconds and they come off clean. I just use light pressure so I don't sand the tire with it.
Xrayray is offline
