Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-03-2021 | 07:39 PM
  #10546
ASM's Avatar
ASM
Let me just say that USGT spec motor can take a lot of gear. On our local indoor track 2.8 FDR seems to be just about right. On the large outdoor tracks, I'm seeing 2.3 to 2.5 and on the largest of tracks I heard the state race winner was under 2.0 and had to make chassis mods to get it done. That's just what I'm seeing and hearing here...if it helps.
ASM is offline
Old 05-04-2021 | 05:36 AM
  #10547
R/C Tech Elite Member
Originally Posted by MikeR
It's just more planted over all for me. I was practicing with the 'newer' sets at SD and the track definitely felt slippery (loose and pushy). I swapped to the balloon sets just to confirm and the car was great thereafter. But yeah, I try and save the old sets for the races. I haven't bought new sets of Gravity tires in years. Carpet racing I hear is the opposite.
https://rcracersofsandiego.liverc.co...ult&id=2959555
Carpet for my car was dialed on 1 run fresh sets then once the balloons started the car got slippery to drive.
Glad I saved all those tires for asphalt. After seeing your tires I feel better about my wear on the asphalt.
I was thinking mine was excessive looking like yours. Thanks for the pictures.
MikeR likes this.
Robbob is offline
Old 05-04-2021 | 07:55 PM
  #10548
Raman's Avatar
I find worn in tyres to work well on black carpet. The trick is to not allow them to balloon however. Ive achieved this by only using SXT for cleaning the tyre and prepping tyre for race. Any other product combination makes them Balloon
DARKSIDE likes this.
Raman is offline
Old 05-05-2021 | 04:41 PM
  #10549
Airwave's Avatar
Pro tip-
For medium/low grip asphalt the more ballooned the better and comes about naturally with many miles of use with lots of traction sauce used. The ballooning creates an airgap that helps with the traction. These beat up 3year old tires, even with the grooving, are .5 seconds faster than my newer ‘flat’ sets.
That's really bad news... It will probably make the things more complicated... People breaking in tyres before races.... Then resulting in new rules about tyres profile...
Airwave is offline
Old 05-05-2021 | 08:15 PM
  #10550
STLNLST's Avatar
Just a thought but when you go to grippy tires your car will body roll more and bottom out. My rear shocks are firmer than the front to keep it level and carry the extra speed the grippy tires generates Try the next firmer rear spring and see what happens.
what car and springs are you running in USGT? Also...I just received my P1-Z and have it side by side with my original P-Zero and noticed little cosmetic differences. What did the changes do for performance?
STLNLST is offline
Old 05-05-2021 | 08:25 PM
  #10551
MikeR's Avatar
Yeah a tire that gets better the older it gets. How terrible that must be... my man lol.
EXO6. As you noticed, cosmetic reasons. Didn't notice any difference on asphalt. If I did it's psychosomatic.
robk and NutDriver like this.
MikeR is offline
Old 05-05-2021 | 09:02 PM
  #10552
lol can't really make the tire that way unless you soak them in sauce then spin them up on 3 or 4s to stretch them. Still won't have that inner wear, sanding the tire is illegal.
Xrayray is offline
Old 05-10-2021 | 03:00 PM
  #10553
Airwave's Avatar
Soaking them is totally possible, and if you want to use the insert, you don't have to centrifugate, you can make them roll by two on something hard... And it will be very hard to detect sanded tyres from used tyres...
Airwave is offline
Old 05-10-2021 | 05:23 PM
  #10554
OSherman's Avatar
Sanded tire rule is bogus. Only way to enforce/control it is to mandate new (marked) tires be bought at the event. Which may happen at organized big races.
Otherwise at club races, sand away till your hearts content. Altho it’s really not needed with the rite sauce and warmers. Mighty Gripper Yellow is what I hear.
$0.02
Raman likes this.
OSherman is offline
Old 05-11-2021 | 03:18 PM
  #10555
Welp, got my body done! can't wait to run it into a wall the first time its out...
OSherman, Raman, DARKSIDE and 6 others like this.
skimax is offline
Old 05-11-2021 | 03:36 PM
  #10556
Now that is a real GT!
DARKSIDE and simple like this.
dman18t is offline
Old 05-11-2021 | 05:01 PM
  #10557
Dayum, so nice.
Xrayray is offline
Old 05-11-2021 | 08:23 PM
  #10558
Raman's Avatar
Mercedes makes Sedans.. there is no way that’s a GT car.. it must be a look alike body 🤣
Raman is offline
Old 05-12-2021 | 01:20 PM
  #10559
VegasHB's Avatar
Isn't there a rule in place that tread across the face of the tire must be visible? What's keeping everyone from just sanding down to slicks and ballooning your tires? Pretty sure our track had or has a rule that all tread must be visible
VegasHB is offline
Old 05-12-2021 | 03:43 PM
  #10560
no one is really checking those. After about 3 race days, the siping on the fronts look smaller and shallower anyways.. Should wear to semi slicks within the summer race series.
Xrayray is offline
