USGT
Technically it should have an air dam above it, but with rc bodies, the air can get inside the body if you just set it on the splitter.
Arrma infraction has one that works.
Splitter works by being close to the ground and causing low pressure under it. Check out Time Attack cars, none are angled. It splits the air, making the air flow faster under it due to the low height.
Same reason that your AC intake is at the base of your windshield. And why muscle cars and Nascar have engine air intakes in that spot. High pressures at the base of the windshield creating a bit of ''ram air'' effect.
Measure the surface area of the splitter. Multiply each inch^2 by say...... 8oz's of pressure. You can have hundreds of pounds of downforce there easy. 4-8oz is about how hard you can blow on your hand. Hold your hand out of a car window, you can feel that just 60mph is much more force than that.
Yep. The front bumper is like a snow plow. All of the snow buildup, air in this case, becomes a high pressure zone that pushes down on the front splitter. A blunt car nose, like the caddy, will produce more downforce than a swoopy vette nose. High pressure due to the blunt bumper above the splitter. Low pressure below.
Had a few issues this weekend with Tire Prep. Anyone have a procedure they use for USGT and VTA they'd be willing to offer up? Or point me in the right direction? I did a search and didn't find a outline of a procedure.
Oh forgot to add Black Carpet (More like Black Ice).
What procedure is used by the fast guys at your local track?
Sounds like things might be a bit different at your track. All of the black carpet tracks I've visited only alow SXT traction compound. That 'blue liquid wrench in a bag' sounds like off road tire voodoo.
I am guessing all the random tire additives are fighting causing it to be slick ... or it's not CRC black. Our CRC Black with an SXT groove will pull the dirt off your shoes.
-USGT spec tires shouldn't need anything other than SXT applied before the run.
-VTA really need to be warn in with lots of SXT or heat cycle them a few times with tire heaters applying SXT (and let dry) in-between cycles.
Not sure if it's allowed but there are 3+ levels of SXT. The MAX can help the VTA tires before they are broken in, but really shouldn't be necessary on the USGT tires. By any chance did you glue the sidewalls? I accidentally put a set of glued side walls in the rear and that was a drifting nightmare.
6563Likes
