Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 01-07-2019 | 07:06 AM
  #8221
godzukihop's Avatar
Originally Posted by bertottius
Come on Clayton. You could run a brick and be competitive with it.
We all took a vote and for Slowbirds Clayton will have to run a Can-Am motor and gearing and weigh 1450 grams.
Sorry Clayton, no room for discussion.
godzukihop is offline
Old 01-07-2019 | 07:58 AM
  #8222
Originally Posted by zxcvb1t
Why not give tamiya gt wing sets a try? Floks run at tcs events seemed to run tamiya gt wings only....
I guess it is worth a shot. Didn't even know it was a thing. Do I need to add post to them? And where do I get those?
s14_tat is offline
Old 01-07-2019 | 11:31 AM
  #8223
bertottius's Avatar
And he has to run a Grasshopper
bertottius is offline
Old 01-07-2019 | 02:01 PM
  #8224
moparSRT's Avatar
Originally Posted by s14_tat
If Tamiya would make a true light weight body that weights 100 grams painted instead of 139 grams for the light weight and 152 for the full weight one, i would run it all day everyday. The issue is that the weight is all on the top and makes the car drive like a dump truck that wants to tip over constantly. I even increased the weight at the chassis by 30 grams to try to offset it and it still wants to flip over.
The nsx body lower cg and profile than the venom gt and looks way better. These are my my actual cars.
Is that the lightweight version ?? ... 47353
moparSRT is offline
Old 01-07-2019 | 02:40 PM
  #8225
CY8Racer's Avatar
So this is like Australia Supercar rules. If you win you keep adding weight until you can’t win? Lol. I thought it was pretty even with me running can am against open motor and a taller gear.
What doesnt kill you makes you stronger right?
CY8Racer is offline
Old 01-07-2019 | 03:02 PM
  #8226
fat500's Avatar
First look at the numbers I'm in third position look at my fastest lap same as the first position driver and he's one of the top racers in our entire state of Sunny South Florida he was running a x-ray with a p zero second place car I believe was an awesomatix also running a p zero. My car was a Tamiya ta07 with a Tamiya raikari gt body. I would have finished slightly better had I not clipped another car during passing him and ended up on my lid but I was able to fight my way back up through the remaining 7 cars . The Tamiya bodies work but you have to make them work . First thing you need to use the Tamiya and lightweight Wing set which I use on all of my body's I also have a P0 that I run with sometimes just to mix it up and that uses a Tamiya lightweight rear wing they are excellent
fat500 is offline
Old 01-07-2019 | 03:05 PM
  #8227
fat500's Avatar
Here are the three bodies I currently alternate between noticed they all have Tamiya lightweight rear wings the NSX provides more neutral handling the raikiri is the most aggressive and the fastest of the three the p 0 handles very similar to the NSX.
DBM and s14_tat like this.
fat500 is offline
Old 01-07-2019 | 03:07 PM
  #8228
fat500's Avatar
Side shot of the body so you can see the profiles and the wings and Wing mounts. On the Tamiya bodies you can adjust the angle of the rear wings notice the difference between the NSX and the raikiri. That little adjustment makes a huge difference in the handling of the body and the way the car rotates in the corners
johnzhou2476 likes this.
fat500 is offline
Old 01-07-2019 | 03:12 PM
  #8229
fat500's Avatar
Keep in mind I use the full sticker sets on my cars I put the paint on nicely and I use all the mirrors the green nsx-r weighs 135 grams the P0 weighs 94 grams the rikarai 121..
fat500 is offline
Old 01-07-2019 | 03:18 PM
  #8230
fat500's Avatar
Here's a nice Top Shot so you can see the profiles
fat500 is offline
Old 01-07-2019 | 03:20 PM
  #8231
fat500's Avatar
I always used tire decals and all this to me is what keeps the class fun the realism and I've gotten lots of other drivers to stop running cookie-cutter bodies and come over to the realism Camp once they see it is possible
DBM likes this.
fat500 is offline
Old 01-07-2019 | 03:27 PM
  #8232
fat500's Avatar
I have a Venom body coming with af1 paint lab decal set that I will do up really nice with a Tamiya lightweight wing and side mirrors and all I'll post pics and report back on its performance compared to my regular runners when I'm finished with it
fat500 is offline
Old 01-07-2019 | 05:13 PM
  #8233
I am not racing with my raybrig nsx because that is a discontinued body. I tried to race with the 2005-2007 body which is quit different. It is stubbier and the back is taller. Where do I find the post with the light weight wing? I will give it another shot. The body once I took off all the gorilla tape weights 138 grams. This is the busy I tried and failed with.
Is this the wing? http://www.rcmart.com/tamiya-54729-racing-wing-carbon-pattern-p-71140.html?cPath=438_880
s14_tat is offline
Old 01-07-2019 | 05:17 PM
  #8234
That is the Raybrig version. The light weight doesn't come with decals.
s14_tat is offline
Old 01-07-2019 | 05:20 PM
  #8235
If he is as fast as you guys say he is, he needs to run a lunch box. Grass hopper is too fast.
CY8Racer likes this.
s14_tat is offline
