Like Tree6280Likes
USGT
    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech ForumsThread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Old 10-20-2015, 07:36 AM
  #4306
NutDriver's Avatar
Trader Rating: 30 (100%+)
If you run shock bladders and the shocks had a proper oil level, I would doubt the shock oil emulsifying being an issue. A loose screw or a shock collar moving are more frequent culprits.
NutDriver is offline
Old 10-20-2015, 07:53 AM
  #4307
Thanks for the input. I still have to open the shocks up and take a look. Everything was tight, just the shocks felt really soft, perhaps a bladder failed or a c-clip for the the pison came loose.
ErikO is offline
Old 10-20-2015, 08:16 AM
  #4308
NutDriver's Avatar
When one of my shocks has been low on oil, that corner would be more like a pogo stick, bouncing up-and-down undamped.
Old 10-22-2015, 03:12 PM
  #4309
Fastforward's Avatar
Default Weight
How do you guys get these cars up to minimum weight? I need 70 grams on my USGT and 130 on my Vta.
Fastforward is offline
Old 10-22-2015, 03:18 PM
  #4310
shortcut's Avatar
Trader Rating: 55 (100%+)
I put a sheet of lead under my battery and the rest of the required weight on the front bumper.
shortcut is offline
Old 10-22-2015, 03:47 PM
  #4311
I first add weight to the left or right side, to equal the balance, then I add as much as I can, in the center , under the belt.
mooby64 is offline
Old 10-22-2015, 04:26 PM
  #4312
Thanks for the input. That helps.
Old 10-22-2015, 05:03 PM
  #4313
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Huskerfan1212
So looking to get into the class currently have X-ray t4 2015 not sure if I really like it. So just to try something different I'm thinking tamiya evo 6 or tamiya 419 what are your options about the two ?
TRF419 has been by far the most remarkable drivable car I have ever owned. The speed you can carry into corners is frightening.. the limiting factor is my belief that I'm going to wreck and I hold back. Nonetheless It's allowed me to focus on my own limits as a driver and has greatly increased my confidence.
Prior to the 419 I ran the TB04 Pro II - Similar drive trains as EVO6.. It's a good car but not a 419.
As with any TCs the 419 has its week points.. Main one being the C hubs. If you hit things like I do, you will break them. Switching out the kit foam bumper with the hard one from X Ray, will help a lot.
Raman is offline
Old 10-22-2015, 09:24 PM
  #4314
metalnut's Avatar
Trader Rating: 36 (100%+)
As with any TCs the 419 has its week points.. Main one being the C hubs. If you hit things like I do, you will break them. Switching out the kit foam number with the hard one from X Ray, will help a lot.
The 419 can run X-Ray C hubs? Without any modifications?
Well.. that sure as hell would be a pretty killer combination of performance and durability. Not that my eye would stray from orange anodizing (again), but still
metalnut is offline
Old 10-22-2015, 10:01 PM
  #4315
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Think he meant to say foam bumper.
Dan is offline
Old 10-23-2015, 12:51 AM
  #4316
Ph3nyx's Avatar
I also use the TRF 419
For the C-hub i switched to the TA-05 C-hub , they are more "flexible" , it helped a lot.
i aslo ordered some aluminum C-Hub for TB04 , they'll come soon. i'll see if it worth the money
Ph3nyx is offline
Old 10-23-2015, 03:17 AM
  #4317
theproffesor's Avatar
Trader Rating: 66 (100%+)
Did the hubs work without running on the DCJ's, or did you have to modify them a bit?
theproffesor is offline
Old 10-23-2015, 05:24 AM
  #4318
Mechintosh's Avatar
The Xray Chubs are wider but can be filed down to make work. I have a TA06 and it seemed like every time I put the car on the track a Chub would break, whether I hit something or not. Filed down some 4* Chubs from TC and they worked. I have yet to break a Chub.
Mechintosh is offline
Old 10-23-2015, 12:59 PM
  #4319
Raman's Avatar
I have used both the TA05 and 418/419 style C Hubs. Both break just as easily. The TA05 C hubs work fine with DCJ. The 418/419 style make it easier to service the DCJ since they can be removed with the C Hub and Steering arm attached.
I have not tried the X Ray C hubs.. do they use a 2.6 mm suspension shaft as well?
Raman is offline
Old 10-23-2015, 06:28 PM
  #4320
Default Legal
Thanks to lots of shoe goo and lead weights my USGT now makes legal weight.
