USGT
#3768
I will add onto this. 6000 + is what you want to run. In theory the higher MAH the longer your battery will be in a higher volt range and that = more power. So simple answer is higher mah the better. Now to make things more complicated is the IR or internal resistance of a battery. I have been running 6000 mah batteries because they had a lower IR then most 7200. Lower IR means more power going to use or more efficient vs just wasted on heat. Most battery manufactures do not list the IR of a battery though. So the safe route is a higher mah pack. You will need to add weight to most cars regardless of 6000 or 7200+.
#3773
It's hard to say if the biggest capacity is the best. There is a limit on the physical size of the battery, and max capacity may not be best for the IR. THis is just a theory I have but SMC said their best performing packs (at one point) were not the 7200 or whatever they had but like 6000 or 6500.
#3775
Where can i find a decent usgt set up for a sakura xi sport at?
#3777
Decided to share a picture of my USGT on a messy workbench. This was a 3 months ago when the body was new. Doesn't look as nice, now.
#3779
Trader Rating: 32 (100%+)
