Like Tree4Likes
Yokomo R12
Old 09-19-2010, 11:04 AM
  #241
Originally Posted by landau
R12 shock leaks oil.
1.shock O-ring is slight small,
2. shock inner spacer hole is slight large,
solution.
1, I use tamiya air remover and shock oil.
Soak O-rings with shock oil in remover, and pump.
This dilate O-ring.
2, make a small hole with grue and drill (1.8mm) two spacer/1 shock.
Well, all R12 shocks are leaking oil... since I dont have a turning machine, do the asso spacers fit the shock better??
I'm guessing the O-ring cant handle the movement the spacers let the piston do. So having better spacers should solve the problem.
Quante is offline
Old 09-19-2010, 03:40 PM
  #242
Me_MrTyson's Avatar
The shock design would say maybe they leak rather than blow up...
As they have no holes in the piston where the oil can move between sections of the shock..
Next best thing would be to leak else would create pressure inside the sealed unit.
Every few races it passes the time rebuilding the shocks
Also means full aware of how much shock oil is in the shocks.
Me_MrTyson is offline
Old 09-24-2010, 07:44 AM
  #243
Default Front end
Does anybody have a front end they want to sell? or can somebody make a list of all the parts i need to purchase to have a complete extra front end. I do not want a 12th scale i would like to run this front end on my oval car. email is ok [email protected]
merich401 is offline
Old 09-24-2010, 11:05 AM
  #244
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Anybody got a good carpet setup?
OVA is offline
Old 09-30-2010, 11:07 PM
  #245
I solved my leaking shock problem, ordered the rebuild set from the associated shocks. And as Landau said, the holes in the asso spacers are a lot smaller, these fit the piston quite nice.
On top of that I noticed not all O-rings were compressed!! I also added a small ring so the O-ring would be compressed a little bit.
Now all shocks seem to be leak free and smooth.
Quante is offline
Old 10-02-2010, 10:33 AM
  #246
CanyonCarverR1's Avatar
Is this car better suited for carpet or asphault?
CanyonCarverR1 is offline
Old 10-02-2010, 09:29 PM
  #247
OVA
OVA's Avatar
The R12 won the world championship out door and indoor race...
OVA is offline
Old 10-03-2010, 10:58 AM
  #248
Default Wheels
Do you have to use the yokomo wheels or can you use other brands such as Calandra?
Old 10-03-2010, 11:06 AM
  #249
MackanG's Avatar
Just swap the rear Axel. I was running mine today with a CRC Axel and JACO Prism.
MackanG is offline
Old 10-04-2010, 03:23 AM
  #250
How do most set their droop crews??
The std Yokomo setting gives a lot of spring preload and the front suspension just doesnt seem to work... I need a camber setting of about 3 degrees to make the tires wear ok. Car is also extremely twitchy in the first turn-in, but after that looses steering, the front just doesnt grip.
I'm guessing this is because the suspension is so hard from the preload, the chassis just rotates around the tire and doesnt go into the suspension.
I already tried running only the center spring, but this is a disaster!
Next I'm gonna try to drive the droop like I would any other front end. this means no preload and almost no droop.
I'm also gonna try driving "normal" tires, jaco's, so I know for sure it isnt a tire problem.
Quante is offline
Old 10-04-2010, 04:59 AM
  #251
Me_MrTyson's Avatar
Will be very interested to hear your finding on jaco's
Was planning on running crc as my test might order some this week
Been playing with droop and the setups u can find on the internet have 8mm droop or 7mm
These work fine when.running 3.4mm ride height not 5mm which would need on outdoor tracks
2.5 or 3.0 is normal camber from again the setups on the internet
Even the rc12 5 and 5.1 they used 3 degrees
Old 10-04-2010, 01:01 PM
  #252
HMMMMM.....3 Degrees of Camber is not normal on carpet. For stock .25 to
.50 is normal but rarely no more than 1 degree. For Mod i hear guys running 2 degrees. I would look for a bent kingpin or something else...
Steve
sdunnmcp is offline
Old 10-04-2010, 05:28 PM
  #253
Me_MrTyson's Avatar
Steve
Steve,
Here are some of the setups which was talking about, maybe it is the track but the setups for the most where all outdoors.
Some are from last year and not even R12's setup but shows in Japan 2+ caster is very popular
http://www.teamyokomo.com/jpn/downlo...oto_rc12r5.pdf
http://www.petitrc.com/reglages/asso...ay20091122.pdf
Setup from IIC for 17.5 RC12 5.1 on carpet still 1.5 caster
http://www.petitrc.com/reglages/asso...17.5200909.pdf
This setup is for a R12 from a Team driver and he uses 3 degree
http://www.petitrc.com/reglages/yoko...ki20100828.pdf
Old 10-04-2010, 07:36 PM
  #254
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Steve,
Aside from Andrew's setups, the others are for "Asphalt" which is consistent with what has been said. Not Carpet settings.
RedBullFiXX is offline
Old 10-05-2010, 03:43 AM
  #255
Steve
Yep, I know, been running that track for 5 years now and I've never used more than 1 or 1.5 degrees camber. This and the fact the car isnt driving all to stable (to quote my friend: "I cant believe you keep it on the track") makes me believe the front isnt working and that the car just lifts on the tire while cornering.
I've now set the droop to the 7mm, measured as per setup sheet, and the front feels a lot better when pushing it down.
Hopefully I can test some more this weekend.
I've had some time yesterday so I made the following adjustments:
- Droop -> 7mm
- Center shock: still not very oil tight, replaced by hotbodies.
- same prob (but not that bad) on the side shock, replaced by a CEFX dampertube (still the best to have in the rear, but thats my opinion).
- Rear axle for std rims
When this works well, I'll try going back to the std setup one at a time.
These are all components that I trust that will do a good job.
Quante is offline
