Yokomo R12
#226
Trader Rating: 50 (100%+)
Yokomo R12 Available
Hello Fellas,
I Just wanted to post that I have a YokomoR12 Available if anyone is interested.
Had a chance to run the car this pas few days ............. the R12 is practictly new, feel free to pm if any of you are interested.
Thank You All Again !!!
Alex
Alex
#227
I found a setup I manage to translate in English in some way. However, there is still some information I can get such as front swaybar, front & side springs.
So I looking for someone with some more knowledge in Japanese that can give a hand for those details. Anyone?
Here is the setup sheet.
#228
>Aron0
this is yokomo 12th driver Masayuki Murai (second place last year JMRCA nationals)
August 28th
Indoor paved track (temperature 35C humidity 47%)
Front
Camber angle 3 degree
Caster angle 3.2 degree
Toe angle -1 degree
Skid angle (F-down R-middle)
Suspension Brock optional 0.5mm including kit (standard 0mm)
Spacer under sus brock 1.0mm
Shock oil yokomo #600
Front spring standard (side by side)
Ride height 4.0mm
Center
Shock length 65mm
Spring yokomo black (optional soft)
Shock oil #400
Shock position (F-middle R-standard)
Roll spring black (optional soft)
Roll spring position (inside, this is not standard)
Roll shock oil yokomo #300
Rear
Rear tread width 168mm
Ride height 4.0mm
Ride height spacer 1.25mm down
Tire F yokomo L-rubber medium 43.5mm(additive 2/3, 10minutes)
Tire R yokomo L-rubber medium hard 44mm(additive full, 10 minutes)
Wheel R & F standard
Electric
Motor nosram 4.5T (timing insert : -10)
Spur/pinion kimbrough 88T / yokomo 22T
ESC nosuram V2 (setting 0-3-5-2)
Servo JR 3650
Body zytec or AMR (posting position Font-hole:1 Rear-hole:3)
Transmitter KO herios
these pic are last 11th September
August 28th
Front
Toe angle -1 degree
Ride height 4.0mm
Center
Shock length 65mm
Shock oil #400
Rear
Ride height 4.0mm
Electric
Servo JR 3650
#229
Thanks for your help Landau-san, that is highly appreciated.
Clear and full pdf available
#230
if anyone is interested i have spoken with john at bsr tires, and he is willing to put foam on the yokomo rims. email him and send him your rims with what foam you want.
#231
Toe in
Having problems with toe in..
Turn the steering completely to the right or left pushing up the front arms the wheel no matter what I do always has toe in..
This seems to be something which appears with the lower arm are attached to the front shocks is there something which I am missing???
#232
Second Question..
Anyone worked out what effect the droop has on the car??
It would seem droop + front shock + lower arm + anti roll bars all effect each other..
Anyone able to shed ligt on the effects of each...
#233
But I hardly think you will steer that much, if you are you need a lot more steering in your car, I usually have a steering circle of about 1.2m.
2nd question:
I almost have 0 droop on the yokomo front (and thats the way I like it), I suspect the droop on this front end will do the same as droop on the other front ends.
The more droop you have the more steering you loose when accelerating because the suspension can lift more.
Anyway, I'll be trying out the car for the first time today. I've glued up a whole lot of tires a few days ago and I hope to find a working combo.
I'm putting my hopes on the soft rears (seems to be magenta-like) and the medium fronts (also in the magenta-purple range).
#234
Steve
#235
R12 must be the best 12th on the market..
finally got time to test
running
800 - front shock
500 - center shock
350 - center side shock
Gold center spring
no springs on the front shock, and silver front arm spring (kit)
Tire super grip rear hard front all Yokomo, Glue them yourself makes for such a better tire.
Car has so much front steering had to dial it out a little...
Overall very impressed the front real makes this car...
running
800 - front shock
500 - center shock
Gold center spring
#236
Finally managed to do some testing.
First tires:
Tire rear soft seems to be pink-like
Super grip rear tire is grey/white-ish.
L-rubber front medium is magenta-ish.
Combo what worked well for me was Tire rear soft and the front mediums.
Super grip rear with the front mediums made the car have too much steering.
To gain steering throughout the turn, I dumped the stabiliser and the car worked very well. Rest is std kit.
I did however manage to loose one of the bottom podplate screws and the other 3 were loose.
Center shock is leaking, I was advised to use green slime on the O-rings to counter this.
First tires:
#237
R12 shock leaks oil.
1.shock O-ring is slight small,
2. shock inner spacer hole is slight large,
solution.
1, I use tamiya air remover and shock oil.
Soak O-rings with shock oil in remover, and pump.
This dilate O-ring.
2, make a small hole with grue and drill (1.8mm) two spacer/1 shock.
solution.
This dilate O-ring.
#238
running
800 - front shock
500 - center shock
Gold center spring
running
800 - front shock
500 - center shock
Gold center spring
Thanks,
Kane
#239
#240
solution.
This dilate O-ring.
solution.
This dilate O-ring.
