Losi XXX-S
I have already placed an order for the composite outdrives and i don't have the extra money for alloy ones. Do the outdrive saver rings stop the composite outdrives from breaking? Could someone please tell me how they work, because i'm not sure.
does any body have a pic of the out drive savers and how they go on
THANKS
THANKS
Alright, stupid question here!!
We run Purple/Plaids at our track, and I was about to order some from stormer and noticed that they have 26mm, 28mm, and 30mm. I'm a little confused as to what these sizes refer to. is that the tread width? If so, I have no idea what to get. I have some TRC purple and plaids on my car now, but when I bought them, i just got the ones that were at the hobby shop since there weren't other sizes offered.
I'm most likely going to cut them down to 59mm, but I want to make sure I get the right ones first!!
Can someone also recommend a nice set of calipers?? The person who i used to race with has them, but he no longer races. I'm on my own now...
i have a idea
i was thinking (1st mistake!)
that i could get a HV maxx system in my XXX-s,
has anyone tryed
yes i know its 14.4 volts and needs two batts and is a 550 size
but i think i can do it
has anyone tryed
Originally Posted by thedudeaturdoor
i have a idea
has anyone tryed
has anyone tryed
If you do this please take some videos..I want to watch when it goes airborne at 95..
[QUOTE=Keith Billanti]
youll want 28mm
belt tooth cutting
whats the best way to cut every other tooth off of the belts?
nail clipper.
THe nail clipper method works as does just upgrading to the new black belt. Clipping that one is not needed as it is relatively free...
thanks, never even thought of nail clippers, What would be a good starting point for jaco foams on carpet? i'm running 19t on a relatively open track?
do you have a pic of how the outrive savers look or a place where i can see it or if you can post?
and the same question for 2- bad
thanks
Originally Posted by TL_XXX-S_racer
Gearhead: ok thanks. Yes if you can please post a pic of your car I would appriciate it. What if I dont dremel the slots out? Can I leave them and just make a modification to how I use the battery tape. Like can u put a longer screw through the back, with the battery strap kind of leaned up as it goes towards the back.
Thanks for your help
Chris
Chris
off topic, but do xxxs 1.15" shock springs fit associated threaded touring shock bodies.
thanks,
thanks,
