Losi XXX-S
#961
Originally posted by mike_Webb
Mark- The graphite Conversion Kit for the XXX-S..... does that include all the rear hubs you can buy and all the Front Carriers that you can buy right now so I will have all the degrees of changes?
Mike Webb
Mike Webb
Ron - what is the low-down?
#962
I think that is the part number for the whole unit...he is just looking for the bone and not all the other stuff.
Mike Webb
Mike Webb
#963
Mark- Edit that picture on your page to take out some of the front carriers
Just Kidding.
Mike Webb
Just Kidding.
Mike Webb
#964
nitrorcfan,
The inner pivot mounts will be available by the end of November. We are creating a brand new website just for the Losi XXX-S Parts that we are producing. Web address will be announced here once the website is complete
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Steve Wang
Speed Tech R/C
www.speedtechrc.com
#965
Regional Moderator
Rocket Ronbo, just sent you a PM.
#966
Regional Moderator
Guys, would anybody know if Trinity or SpeedTech have or gonna have 2 and 4 degree aluminum caster blocks and spindles? Thanks.
#967
It's pretty much agreed that the XXX-S is a pig (ie. overweight). If we start changing out the hub carriers, steering cranks, etc for aluminum pieces wouldn't that make the car even heavier? My real question is has anyone weighed the aluminum parts vs. composite vs. "stiffezel"? I doubt the difference in weight between stock and aluminum parts will help my abilities at all, but i'm curious all the same.
#968
Losi Pig
Loose Cannon - I'm not sure if you've done this but change all of the XXX-S's screws from Steel to aluminum. Its quite a dramatic difference in weight. Also put on the aluminum MIP CVD's. Those are 2 pretty significant amounts of weight that can be reduced. If you can get your car to within about an once or 1.5 ozs of weight and you won't be able to tell the difference.
#969
Dave K.
Have you been running rubber on ozite with your xxx-s? I have been struggling to keep the roll speed in the car. I ran the one-way Tuesday at Trackside and still didn't really like the car.
#970
matt....what is you setup....i got my car pretty close....running pauls setup, only with purple and blue spings, and 60 wt in the ft and 50 in the rear....i am going to lessen my rear toe, to try and loosen it up.....let me know...
#971
Ha Ha, The one way is a nasty trick from the boys out west! Beware its evil powers!
#972
Mr. Losi, doesn't Paul L.'s setup have the blues up front and the silver in the rear? Did you find the the blues are too soft up front and scrub too much speed? Foam or rubber?
#973
pauls does have blue and silver....i went stiffer, to rid the car of dumping over in the front....
#974
Hey Mr. Losi, I have the xxx-s. And this weekend I have a big race, rubber tires only. I have been running foams since I have purchased the car. So is your set-up for rubber tires? What rubber tires are you running? I have sorex 24's and 28's. Thanks in advance for any help.
#975
Can anyone help me, I got a yokomo BMS charger but the bad thing is the instruction manual is in japanese, where can i down load a instruction manual in english?
