Losi XXX-S
#9196
Originally posted by jkerr0043
I think what you're talking about is the kickup and the castor block being combined to give you total castor. If you're running the 4F mount in the front and have 4 degree blocks on it, you would have 8 degrees of castor total. I do think you're right though about the effect. I think I was thinking backwards. I don't mess with castor a lot so I seem to get it mixed up sometimes which way it effects the car.
Again, I was talking about how caster affected straight line stability on a real race car. Just assuming that it's fairly similar on an r/c car.
With the 4+4 setup on my XXX-S cars, it is very stable down long straights. But probably turns a bit slower initially.
Funny thing is...My XXX-S has more potential suspension adjustments on it than my fairly straight forward formula car did. Although, some of the adjustments were easier on the real thing.
The other thing about my formula car is that I had no Ackerman at all...I put it together with parallel steering at the spindles to not scrub off speed with the front end of the car on sweeping (flat out) turns at Laguna Seca and Sears Point (now Infineon).
Thanks for making me flex my brain cells...
#9197
R/C Tech Elite Member
BTW Randy, I figured out why I kept burning brushes and going soft after 4 minutes at Norco in Mod. The D5 I was running was cut all the way down to .263". I knew I should have measured it. With those P94 brushes it was probably shorting the comm out the whole time.
I'm gonna give you a call, wasnt going to, but looks like you're still up
#9200
yep, 5 minutes.
#9202
Belt??
I'm not sure what u mean by cutt off the tooth??? from the bell??
how many should i cut ??
i got i'm using yellow belt to run my car.. and i still have blue and another yeloow which one is better..??
if the car got less friction it roll better rite? but it will lose the breaking rite?
i'm new at this..
i'm new at this..
#9203
Hey I got a fun idea. Let's all post pictures of our cars and their mods. That sounds like fun.
#9205
Re: Belt??
i'm new at this..
i'm new at this..
#9206
Re: Re: Belt??
Originally posted by Randman
...with a 1 way...carpet ...
#9208
Originally posted by STLNLST
what class are you running this weekend? 19 turn should be fun. Dujuan, Matt, Alex, and myself are ready to have some fun. Good luck in whatever class you decide to run.
