SpeedMerchant Rev 6 >
SpeedMerchant Rev 6
SpeedMerchant Rev 6
Old 12-18-2010, 09:35 AM
  #226
WIITA's Avatar
Trader Rating: 43 (100%+)
Hey there guys, I am looking to try the new linear side springs on my CRC. What spring would I use that would be compreable to the white CRC medium side spring? Thanks a lot!!
WIITA is offline
Old 12-18-2010, 10:56 AM
  #227
Donny Lia's Avatar
Hey,
Im pretty sure that would be a .20 side spring. Lately the hot setup are the .18's though.
Donny Lia is offline
Old 12-18-2010, 12:05 PM
  #228
WIITA's Avatar
Originally Posted by Donny Lia
Hey,
In your opinion would the .18 have the proper stiffness to transition on the crc? Thanks for the info!!
WIITA is offline
Old 12-18-2010, 09:58 PM
  #229
Donny Lia's Avatar
They should but its just something you have to try. The cars are similar but different so no way to know other than trying them.
Old 12-21-2010, 03:37 PM
  #230
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Donny- What are your current setups for World GT 13.5 and 12th scale 17.5 on a tight, high grip track?
Thanks,
James
JamesArluck is offline
Old 12-21-2010, 04:09 PM
  #231
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by hanulec
Thanks OD -- I almost forgot about those.
Damn i was building my car and saw you post and thought i was an idiot because i put them in the gap on the rod end.. Now i know they were in the right place. I read the manual like 10 times and didnt see any mention of them. Being that FJ built like 50 of these i believed what he said.
Jerry P is offline
Old 12-21-2010, 10:39 PM
  #232
Donny Lia's Avatar
Thanks,
James
Hey James
I posted a setup a few pages back. I'd run the same thing in the WGT car with maybe a lil less camber up front, no pod droop and 4mm ride height all around. That would be a good starting point. Might need .20 side springs too but would have to try it first and see. Haven't run the car since Vegas had .20's in it there. Hope this helps.
-Donny
edit: heres that setup so you don't have to dig. other thing I forgot. super small front tires on wgt car, almost on the rim. also dont be afraid to try .22 front springs on both cars.
Front:
-1.5 Camber, 3 Caster
3.5mm Ride Height
Green spooge on kingpins
.20 Springs
Magenta front tires, 1.59 glued 90% up sidewall
Front tires shimmed out .060" both sides
Center:
35 wt Oil in Shock
1.5mm pod droop
Copper spring
Battery Forward
3.5mm Ride Height
Rear:
Green Spooge in Tubes
.18 Speedmerchant Linear Side Springs <--DIALED
Side Springs just touching
Max width
Pink Rear tires, 1.69 glued only at rim
4mm ride height at rear of pod, 3.5mm at front
Old 01-06-2011, 04:45 PM
  #233
Blue Screw's Avatar
come on guys the thread is dying
Blue Screw is offline
Old 01-06-2011, 05:05 PM
  #234
Default question about front end kits
do the new edition SM front end conversion kits for the other manufacturer's cars use the older graphite cross piece with pressed in teflon Orings? Or do they now come with the new grapite crossbar that has the retainer rings to hold the Orings in place?
vafactor is offline
Old 01-06-2011, 09:59 PM
  #235
LonnyJ1950's Avatar
Hey James
-Donny
Front:
3.5mm Ride Height
.20 Springs
Center:
35 wt Oil in Shock
1.5mm pod droop
Copper spring
Battery Forward
3.5mm Ride Height
Rear:
Max width
What would you change for low to medium grip. Our track doesn't get used a lot so it's very green.
LonnyJ1950 is offline
Old 01-25-2011, 03:36 PM
  #236
Blue Screw's Avatar
hello... how come u dont use reactive caster??? when i ran the trinity front end on... we use long ballstuds in rear and med in front.. is there a reason..
Old 01-25-2011, 04:39 PM
  #237
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey LonnyJ1950,
Try what i marked for you in Red
Hope This helps
Mike
Hey James
-Donny
Front:
3.5mm Ride Height
.20 Springs
Lilac front tires, 1.59 glued 90% up sidewall
Center:
35 wt Oil in Shock
1.5mm pod droop
Blue spring
Battery Forward
3.5mm Ride Height
Rear:
Max width
Yellow Rear tires, 1.69 glued only at rim
Use Protoform AMR-12 body
mike ivy is offline
Old 01-25-2011, 04:50 PM
  #238
LonnyJ1950's Avatar
Thanks, I'll try it.
Old 01-26-2011, 08:23 PM
  #239
we have the option to, but the cars always seem to work great box stock middle/middle and it's what we always work back to.
JoelV is offline
Old 01-28-2011, 10:17 AM
  #240
Blue Screw's Avatar
hey ivy whats up man.. u running the rev still?.. anyword how the speedmerchant crew is doing at the birds..anypic of the cars ornew parts
