CEFX 2010 - A new Evolution.
#751
R/C Tech Elite Member
I have edited my post. If yokomo ant3 could edit there post, Thanks. My intent was not to reveal your prototype, but more to show there is a solution coming. There has been several weeks(or months) with no response of bowing issue. I have 2 CEFX evolution's, and both have bowing issue. I even just bought the new flexi chassis with same issue. Im not saying it hurts the handleing, its just something you gotta get used to. If you hit a wall hard, over the knee it goes.
So again I apoligize.
It states on your website that you dont always get the emails, due to your race schedule or something like that. So why would someone send you an email about chassis? You have avoided posting in this thread for months. I for one, thought you just dont communicate via email or RCTech.
This is the what your website says- "Josh leaves for races on a regular basis & if he is gone, your e-mail WILL go unanswered by anyone until he returns & then could be accidentally overlooked in his overflowing e-mail box. "
#752
Hi Josh,I will be posting 2 chassis and parts back to you to have look at.They may take awhile to get to you as I live in Australia.They both have the same problems as photo's above.I sanded the spur gear mount down before assembly (as you will see when you receive them)
#753
KingKarate - You posted that your car has no bow so what good would that do me?? I'm looking to find mount/motor plates that are indeed bent or something I can find to be the source of the problem. I have two straight Evo cars here that don't have this problem and really I don't need a third.
#754
Handleing problems caused by a bowed chassis.....Set your ride height to 5.5mm at the front and rear at 6mm so you should have about 4mm middle of the chassis.Run it over a small bump on your track with your 13.5 turn at full boost and watch it leap 1 meters in air and land 10 meters down the track in broken mess.Thats how we found out we had chassis problem
#755
It looks to me like its the mounts. I took the chassis apart and found that the mounts are bent. The chassis is flat now. The other car(which i recently sold to a friend) is the same way.
Im just gonna order new mounts for both cars. Hopefully the are straight. I know it may have been my fault as well. I have hit a few walls pretty hard with both cars, but nothing i havent done in other touring cars without problem.
#756
^^^^ I wouldn't bother buying new one's.My new ones were straight as I cheaked them with a steel ruler before installing them and it didn't take much to bend them from new,about 80 laps around our track and never raced
#757
+1 here
I 've checked the mounts and same issue!
We Now know those 2 pieces cause the trouble Can we have a Solution for this please...
We all love this car and don't want to go for any other make of Car...
I know Josh will come up with a new improved version of these mounts...
#758
http://www.rctech.net/forum/r-c-item...ml#post8646576
Roller-new chassis and motor mount with no bow. for sale
If you guys have a problem, e-mail either myself - [email protected] or [email protected] - Angel posted this on the shopping site because most people who would order off the site would send ME ([email protected]) a question about their order and I would either be gone and/or do not handle anything with packaging/filling the orders other than driving them off to UPS or USPS. Order questions need to go to Angel, support questions need to come to me - It's simple.
As far as avoiding this - I HAVEN'T SEEN A PROBLEM via picture or in my hands. Your posted pic is the first I've seen a motor plate look like this. How can I try to solve a problem when I don't even know what exactly it is to solve?? Seriously. I don't have it and I haven't seen a motor plate like this to know.
By all means, send the bent plates back and I will send you a replacement. I can not garantee this won't happen again if you are in a hard impact. I can at least get you a free replacement and have the problem in my hands to check out and change the design of the part for the next batch to be made.
My father works in a machine shop. Since these parts are bending and not cracking/shattering I will do some research into getting these heat treated so they are harder and will not bend. I will have to check with a company to do this and possibly make a fixture so these parts are solid during this process so they don't warp or bend. If this isn't possible, I'll again make a fixture with my dad so we can take a dust cut off the bottom on a surface grinder to make them perfectly flat...... I have no problem accepting there is a problem and fixing it but I need to have the problem in hand so I can make a solution.
#759
Everyone - Save money on the postage and don't send back the chassis or other parts. CEFX WILL NOT PAY POSTAGE TO SEND YOU ALL OF YOUR CAR/PARTS BACK!!! Just send the motor plates/mount plates and we will send you replacements. I'll update everyone asap about the heat treaded ones as soon as I have that sorted out.
Just so you guys know, I've run the same mount/motor plates on my Evo since the WC in Germany. I know the problem comes from crashing. All the inventory we have in stock here is straight as I've gone through them all....
#761
hey josh.. i am trying to order a couple things from ur site but its not letting me.. what do i have to do im am trying to get it here for the weekend
#762
Blue Screw - www.cefxspeedshop.net - ?? The .com site is the new one underconstruction so don't use this one. If you are having trouble, try logging out and then back in. As far as I know everything should be up and running but I'll check with Angel if there's a problem with it.
jflx - Titanium I don't think would be a good choice as it's soft and will probably bend just as or easier. Carbide?? I'm guessing that would be super expensive and probably shatter. We use carbide tooling to cut the graphite and they are super easy to snap if used incorrectly. The best choice will be a heat treat for what we have now and a re-design part that fills in the area between the motor mounting slots and the holes for the graphite mount.
#765
re-design pls
