Tamiya FF03
#872
Hey everyone,
Was just wondering if anyone here is running their gears dry?
I only plan on running a Sports Tuned in there so nothing too crazy.
Thoughts?
Cheers..
Thoughts?
Cheers..
#873
I've also have been driving the car with a 23T super stock motor and i don't hear anything strange about the gearbox.
#874
Tamiya party.....
my info ninjas just told me..
a huge shipment of tamiya parts arrived at speedtech. including the mythical FF-03 aluminum spur gear holder
http://www.speedtechrc.com/store/ebp...id=896&id=9800
#875
#876
#877
Any thoughts on whether it is worth getting an FF-03 Pro over an FF-03 kit? Bearing in mind I'd like a Civic shell and I'm not sure it's out as a spare yet.
#878
If not racing, go ahead and get the non-Pro version..
whichever path you take, be sure and build the plastic diff correctly... wish i hadnt made that mistake..
#880
Have got the Cyclone drive shafts to fit with no mods, just needed a 0.3mm shim in each side to take out the slack.
One thing I noticed, and it is a major design fault ..... the original drive axles run against the hub holders when on full lock, which could be a reason why the diffs kept going?
Still not got a diff for the car so no racing with it this weekend
#881
just wondering if anyone can share their setup for outdoor?
Im using box stock setup but not sure what oil to put. I just have 70 f / 35 r with blue/yellow springs. 0 droop front and 2 mil back running sorex 32's with med inserts on both.
Need the car to turn in more
thanks.
thanks.
#882
thanks.
thanks.
Reduce front oil weight
#883
I'm running my car with 40wt oil front and rear, 2 holes in piston and blue spring at the front and yellow in the rear.
This gives the car plenty of steering at an indoor and outdoor track.
#885
