Tamiya FF03
#2956
Aluminum screws are in the plans... for the bits that can't be glued effectively. But we'd be talking a few tenths of a gram of epoxy would replace 13 screws. Each screw is worth around .8 grams.
Speaking of which. For 32mm turnbuckles. The aluminum version is .9 grams lighter than a steel turnbuckle. ..... I shouldn't have bought aluminum turnbuckles. That's totally not worth the dollars per gram.
The gear cover is 4.1 grams. The two screws are .5g each. So... 5.1 grams for ditching the gear cover.
#2957
Yes, there are, for most classes. But not for USGT FWD cars.
http://www.usvintagetransam.com/rule...s7-20-2017.pdf
Chassis Specification:
Any 1/10 4wd or Fwd sedan with 4 wheel independent suspension
Weight Specification:
4wd Minimum 1380g in race-ready trim
Fwd no minimum weight
#2962
You can build a FWD car light mine (Not a FF03) is down to 900g, problem is once its real light getting enough bite with the USGT tires to compete coming out of the corners is an issue. If they'd let FWD run open slicks against the 4wd cars on USGT tires it will compete. A soft slick on the front is the way to go.
#2963
it's going to have some adverse effects on initial steering, but setting up the car with a big front weight bias might help that. Then again, FWD is FWD. The place a ultralight car should "win" is in braking zones and in cornering.
Any downforce you get, is going to have a larger effect. Lower tire loading means you can corner faster. Lower weight, also means you can gear higher, so there may be a top speed advantage.
#2964
I have a 75/25(F/R) weight bias on mine now. It has more weight up front then you can get on the FF03, it has anti-lift in it. It still gets killed off the line and out of slow corners.
Brakes on a FWD are not the best thing heavy braking will give you a bad push. If the course is flowing and has large radius curves it works great. If it has a couple of sharp 90s or god forbid a 180, then the old shaft drive Awesomatix will kill it and that's with Alberta Scale Spec rules of 4wd weighing 1450g and FWD having no weight limit.
#2966
#2968
