Hot Bodies TCX
Old 10-30-2010, 12:36 AM
  #1216
Trader Rating: 21 (100%+)
Originally Posted by LOSIRACER77
ok guys i thinking about going touring again, is the tcx wroth the money???
and what is a good carpet setup for jaco blue tires?? and what else would i need to make the car handle??
Good car overall, and the price point is slightly lower than others. Just know that tuning parts are hard to come by and parts support is lacking in general... Thus I have moved on...
peter_robinson is offline
Old 10-30-2010, 10:40 AM
  #1217
Airwave's Avatar
Originally Posted by j86
Just saw these on the 3racing website for the Sakura Zero...
Has anyone tried the 46mm Swing Shaft For 3racing Sakura Zero (#SAK-40A)
or the Universal Shaft 46mm For 3racing Sakura Zero (#SAK-40)?
Not sure if the pin is long enough or is it a tad bit shorter like the Tamiya ones?
os.3racing.hk/products.php?products_key=4702
os.3racing.hk/products.php?products_key=4701
Yep, I tried, the problem comes from the pin, effectively, its diameter is too small to fit in the spool...
Airwave is offline
Old 10-30-2010, 06:04 PM
  #1218
shanty140's Avatar
How many teeth should I get for a pinion on this car with a 17.5T motor on a 40x80' carpet track. As I know from off road it can come down to driving style and other factors, but what would be a good place to start?
shanty140 is offline
Old 10-30-2010, 11:07 PM
  #1219
VooDooPH's Avatar
Trader Rating: 18 (100%+)
not sure if this has been tackled here before, but i seem to have a problem with the outer hinge pin rubbing against the wheel on full lock (left or right). anyway this can be remedied other than dropping the EPA?
Thanks!
VooDooPH is offline
Old 10-30-2010, 11:32 PM
  #1220
Korey Harbke's Avatar
Thanks!
Mine clears perfectly fine. Maybe try different wheels? Those look really thick.
-Korey
Korey Harbke is offline
Old 10-31-2010, 01:34 AM
  #1221
Thanks!
Only used Sorex/Revlite (Pre builts) on mine and no problem.
markrobinson is offline
Old 10-31-2010, 04:19 AM
  #1222
shanty140's Avatar
What spare parts would you guys recommend to keep on hand for the TCX.
Old 10-31-2010, 04:53 AM
  #1223
VooDooPH's Avatar
arms (front and rear), chub (4 or 2deg depending on how you run). uprights if you're still running the composite ones (might want to upgrade to the alum ones), outer suspension pins and belts.
VooDooPH is offline
Old 10-31-2010, 04:54 AM
  #1224
VooDooPH's Avatar
-Korey
Thanks... the rims shown are from TOP... no choice but to run them as they're the spec tires in the series we're currently running... :/
VooDooPH is offline
Old 10-31-2010, 09:45 AM
  #1225
san.'s Avatar
Trader Rating: 61 (100%+)
Rear Arms for sale.
-San
san. is offline
Old 10-31-2010, 11:03 AM
  #1226
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
A lot of us have ran top rims on cyclone/tcx.. What hubs are you running?
Owen RaCing is offline
Old 10-31-2010, 07:15 PM
  #1227
Suspended
Trader Rating: 86 (100%+)
has anyone try steel 44mm use as front axles?
will it pop out?
still having trouble finding 44mm steel dog bones for my tcx.
i m now using tamiya 46mm but it has too much play in pool out drive
also have anyone try 6mm rear hubs? any choices besides hpi hubs?
littlealex is offline
Old 11-01-2010, 12:05 AM
  #1228
VooDooPH's Avatar
The stock ones... i think they're 5mm?
VooDooPH is offline
Old 11-01-2010, 12:09 AM
  #1229
VooDooPH's Avatar
will it pop out?
i think tamiya's silver colored huibs are 6mm...
can fit a Tamiya TA05 steel outdrive to the spool... need to sand the ends of the spool coupler or dremel a slighlty larger hole on the outdrives for them to fit... then you wouldn't have any problems running the 46mm universals from tamiya/3racing. hths
VooDooPH is offline
Old 11-01-2010, 01:26 AM
  #1230
Airwave's Avatar
Are you sure it is not coming from you aluminium knuckle arms? Are you sure that the offset is the same as the original?
Airwave is offline
