Hot Bodies TCX
#3827
Faster reaction into corner and more corner Speed. Just need more time for setup testing.
#3828
Yours looks very nicely made. Are the bulkheads and layshaft mounts custom machined or off an existing car?
#3829
The motormount, the brace behind the motor, all shafts and the bearing holders for the middle shaft are custom made. The front/rear bulkheads are original TCX parts.
Also all carbon fibre parts are new, it's the same material i also used for my TCX option chassis that was used by Freddy and Dominik to make the A-Main and Oliver Franke to make the podium finish in ProStock class
regards
Marcel
regards
Marcel
#3830
RIDE
EVA Bumper for TCX
EVA Bumper for TCX
#3831
regards
Marcel
regards
Marcel
How would you compare your chassis on Asphalt compared to the kit HB one? Looks to be the goods on carpet im just wondering if the results have been as good on asphalt. Also, what thickness is the chassis and how wide is it?
Thanks,
Antoni
#3834
setup
Hi
Can anyone help with setup from Andy from race in Japan and the setups from IIC ??
#3836
#3838
How is the Spec-R diff right out of the package? Does anything need to be upgraded right away? (gears, pins, outdrives, gaskets, etc.)
Is it possible to run the DCJ's up front with the Spec-R diff? Or are the outdrives too short?
How do the Spec-R low friction belts compare to the kit belts?
#3839
Trader Rating: 102 (100%+)
Very good once I got it to stop leaking.....it was my fault due to incorrect building.
Gave the TCX great steering feel.
the SpecR top deck was a good add on.
#3840
CASTER 6° ON TCX
Hi Guys!
I would like to know if it is useful to put the caster to 6 ° (on carpet track) as commonly used with rubber wheels or sponge wheels .
Hara, Moore and company seem to have abandoned this solution in their setup on carpet.
What do you think about ?
