Hot Bodies TCX
#1831
Oops wrong thread.
#1832
See you Friday.
#1833
#1834
Guys, just want to know if upgrading to alum rear uprights will equal the rear toe left and right? Mine has 3.5 deg on the left and 2.5 deg on the right. Also saw that 3racing also has alum rear uprights for cyclone which is half the price of HB made one and its also easy to get. Is this good?
#1835
I ve just done building my car last week and its been like that since the first time I put it on my set up station. I have tried to adjust the suspension blocks a few times but its still there. I read somewhere here that the problem come from the stock uprights. I just wonder if getting the option alum one will solve it.
#1836
#1837
#1839
#1842
I had this problem, i bought the 3racing toe blocks and it didnt change anything so to answer your question dameetz, they are fine i think .
But for the toe issue, try changing hubs ...
#1843
I use Jet #CYL-08P
#1844
Front Knuckle : rear Hubs
Go the JET ALLOY Hubs & Knuckles the bearings
Fit better in them, the 3R ones the bearings don't seem to fit as snug,
Found the outer ring on the Bearing could spin unless you used a locking
Agent
Agent
