Tamiya TB-Evolution IV
#3197
Originally Posted by Guo Chean
Hi Guy,
i new to TB EVO 4 may i know will the suspension mount of X,A,B,C,D,E same with the TRF 415 MSX suspension mount X,A,B,C,D? thanks
#3198
Originally Posted by Juan Aveytia
All the blocks work on all the tamiya cars. But, I believe 415 blocks are a little shorter in height.
#3200
Originally Posted by Patriiick
uhh..I have both and i never noticed any difference between the 415 and EVO4 blocks..
#3201
The original EvoIV used the A,B,C,D,E Blocks which are about 1mm higher than the 415/MS/MSX 1XD,1XC,1XB,1XA,1X,1A,1B,1C,1D, and the new 1E blocks. The EvoIV MS came with the 1 "series" blocks (I think). So just look at the blocks to see if it says A... or has a "1" infront of the A or whatever letter block....
#3202
#3203
The "A" block is 1mm higher than the "1A" block. Or.... the "1A" block is 1mm lower than the "A" block...
#3205
guys I'm looking for a setup for a evo4, anybody know if Rod C , DJ, cory lewis, or any other pro ever put up his setup anywhere. I tried pulling up DJ set up on tamiya usa but it would not come up.
Im having problems with the rear end coming out on power.
associated springs gold, silver with 40wt oil
1 1/2 camber all the way around, 0 front toe, and D block in rear
1mm rear antisquat, 4 frt droop, 5 rear droop, 2and2 up travel
front spring 1 hole from top and same with rear
running 2mm in roll center
#3206
#3207
thanks jeff will try . I just wish that you could look on the tamiya site and see what the pro's setup were when they ran that specific car at tamiya. I know I can go to Xray, losi, Ae, and get a setup for the tamiya track. Whats wrong with the tamiya????
#3208
http://www.tamiyausa.com/articles/fe...?article-id=79
#3209
thanks jeff , I tried opening the file there is a problem with it. I tried the last 3 nights
#3210
