Originally posted by B-B Hi Guys, Iam going to be installing lowered pods on my L4 as soon as I get them. I have been truing my tires down to 45mm with good results, but when I did I had the #4 adjusters in the stock pods and the ride height was good at about 3mm. but I dont have any adjustment left as the tires wear. With the lowered pods running my tires at 45mm what # adjuster should I start with so I could get a little more wear out of the tires? Thanx Bill I'm not sure without trying it on one of my cars but I think an AE #2 down will get you about the right ride height at 45mm. When you get your new pod plates try it yourself. I'd like to suggest that you get a set of the new IRS ride height adjusters. They come in '0' (middle, same as a three, or ...) through '3.5', in .5 mm increments. These will make getting just the right ride height easy. I've just started using them and they are the best thing since sliced bread! |
Hey OD,
Where did you get them from? Dusty |
Thanks od , I will start with the #2s Iam sure that will put me in the ball park. I ordered the IRS pods and their adjusters also . Are you guys going to be at Hobbyworld Fri. night? Thanx Bill
Originally posted by B-B Thanks od , I will start with the #2s Iam sure that will put me in the ball park. I ordered the IRS pods and their adjusters also . Are you guys going to be at Hobbyworld Fri. night? Thanx Bill Little Bill |
I'm still waiting for my IRS adjusters to get here, I ordered them in the middle of the snowbirds... I hope to see them before the weekend....
Hey Bill how was your trip overseas? Missed chasing the 76 car last Sat. LOL . Hope to see you soon. Thanx Bill
Originally posted by B-B Hey Bill how was your trip overseas? Missed chasing the 76 car last Sat. LOL . Hope to see you soon. Thanx Bill It was equivalent to drift car racing on that wood gym floor surface. You needed a steady finger on the trigger. Fun for all! I may come to Gilroy on Saturday. Little Bill |
I had just bought the lunsford titanium front axels for my l3 and when I triend to install them, i noticed that the threads were too large for the steering knuckles. I was wondering if anyone else had this problem? And if so, which size of a bit to use to enlargen the holes.
Originally posted by Switch Blade I had just bought the lunsford titanium front axels for my l3 and when I triend to install them, i noticed that the threads were too large for the steering knuckles. I was wondering if anyone else had this problem? And if so, which size of a bit to use to enlargen the holes. |
Switch Blade - Just line it up, screw it in and then install the locknut on the back. You'll also need to file a little off the arms so there is no binding.
Put the holder on the kingpin before you put the Lunsford axles in - the axles do deform the hole that the kingpin goes into so you'll either have to shave the kingpin hole (pain and not so precise) or put the axle in after the kingpin - better and since the holder doesn't slide on the kingpin, it doesn't make any difference.
Further truing adventures
Okay - I was able to get my fronts on my truer but not the rears - do I NEED to cut down my rear tires?
I'm running grey/green/pinks on the rears and purple fronts (I'm going to try magentas as well. . .) |
You don't HAVE to do anything... Everyone has their own starting point.... I seem to get a lot of rear tire wear with grey's so I start the tires at 50mm....
roll out
how do you know what roll out is good for your track? Is there some sort of mathmatical equation to find out. Or do I just need to be a jedi master lol.... No for real, what do you guys do !!??!!??
| All times are GMT -7. It is currently 11:15 PM. |
