I like RW spur gears, they only take 8 balls but seem to last alot longer then kimbrough spur's. I generally go 6-8 runs in between rebuilds and only replace the hardware when it needs to be.
At the moment I'm using A normal size servo (digital, Hi-tec HS5925). It's A really strong servo and it's also fast (0.08 sec)
But it looks like everyone's using A mini type servo, is it really necessary (if so, why) and is it worth to invest in? |
Mini is for weight and also most cars wont even accept a full size servo with the servo posts and mountin positions on the chassis.
Futaba 9650 is where its at. Hitek's dont center for shit, Futaba's center great all the time :) Also you dont need that much steering strength to steer a 3 lb car. |
Whats the transmission ratio on a 12th scale?
i would think that depends on your spur, pinion and tire size, its infinite really, unless im an idiot
Originally posted by primusblowsgoat i would think that depends on your spur, pinion and tire size, its infinite really, unless im an idiot |
Originally posted by JDXray Then how do you find all those rollouts on gearchart.com You need the transmission ratoi, spur,pinion, wheel size. BTW... I have a whole chart printed out for a 96 tooth gear, I'll copy it if you want.... |
i dont know what the exact forumla is but its pretty simple, all you need is your spur size pinion size and tire size
Originally posted by vtl1180ny Jon... It's 1:1..... BTW... I have a whole chart printed out for a 96 tooth gear, I'll copy it if you want.... |
Originally posted by Clegg Mini is for weight and also most cars wont even accept a full size servo with the servo posts and mountin positions on the chassis. Futaba 9650 is where its at. Hitek's dont center for shit, Futaba's center great all the time :) Also you dont need that much steering strength to steer a 3 lb car. I'll see if I can find that servo somewhere so I can test it. And I don't have any problem with Hi-tech servo's. But I'll have to admit that I've never used A Futaba servo, so maybe if I do I'll say something different!:p |
Originally posted by Tekin Thanks, I'll see if I can find that servo somewhere so I can test it. And I don't have any problem with Hi-tech servo's. But I'll have to admit that I've never used A Futaba servo, so maybe if I do I'll say something different!:p |
servo
i agree. I used a 9650 for a whole season in one of my cars and while it centered well enough the gears got really sloppy after a short time. The KO 949 is far superior.
Hmmm.... this makes me confusing!:weird:
Are there other opinions about the mini servos? And are there other servo's I can choose from? Since I'm very satisfied with my current Hi-tec servo, I was thinking maybe this servo could be A good pick: HS-5245 Did someone tried this one? I've seen lots of (team) drivers using the Futaba, so I guess it couldn't be that bad.... |
I'm currently using a Hitec because it was all I could get locally but I'll be going Futaba digital in the near future....
| All times are GMT -7. It is currently 08:10 PM. |
