Originally posted by WVRACER so is the thickist t-bar from associated the way to go for carpet or is there a different manufacture you guys recomend. i just started with these and i need to stock up on parts Rob So much in 12th is driver preference. YOu can run a thin t-bar on carpet too. Especially on bumpy or wavy tracks or low grip tracks. |
Powerpush t-plates
These are sweet! More thickness choices too. http://www.teampowerpush.com/catalog.html
Re: Powerpush t-plates
Originally posted by Jay Boyd These are sweet! More thickness choices too. http://www.teampowerpush.com/catalog.html |
Ray i know Tonys stuff is good but is it justified paying the 9.99 vs. the 4.50
also what other parts are needed as in hi replacement stuff thanks rob |
This last weekend was weird. Traction was med-high???? It was Ozite-but only Niftech was being used. I had a thick-tbar, silver center spring, Magenta fronts sauced 3/4, CA on the rear Grey tires and that was just about enough steering. A tad too much when the d/r was too high-as i found oout the hard way one run (BANG!!) But this set-up would normally be undriveable for me! I usually run thin t-bar, green spring and Purple front and Pink or big Grey rears in back in med to med high bite.
wvracer-just get a few rebuild kits for your shock, extra fron springs because in a crash or just over time they lose there strength and collapse. Body posts and the black plastic pillow balls in the arms. Those you want to fit snug-but not binding-but definatley not sloppy. Yu might break a lower arm on occasion, but get the lowered arms to get more life out of you tires. You can buy thin washers or shims (IRS has them in different thickness) to space the arms back-up. Ray |
Cutting the rear axle
Has anyone cut a little bit off the rear axle to reduce rotational mass on their l4? If so how much to cut off?
Re: Cutting the rear axle
Originally posted by revzalot Has anyone cut a little bit off the rear axle to reduce rotational mass on their l4? If so how much to cut off? |
Originally posted by CypressMidWest Crashby: Link cars were PREVIOUSLY outshone by T-bar cars in Mod, because link cars tend to be more "free" in the middle of the corner, in mod they would sometimes lose rear traction. Your Rev. 4 has been designed to address those issues, and I've watched them equal or better T-bar cars in Mod. At last years Carpet Nats, Jake Pritchard's car looked AMAZING, as did Brian Jucha's. I'm willing to bet that you'll like it every bit as much, if not more, than the Trinity car in Mod. |
thanks Ray i will stock up. still not shure about the 10 buck t-plates but what the heck i'll give them a try. you would not have suggested them if thay where not good.
i went with the irs lower pod plates and threaded king pins and i got the parma threaded stub axels hope these where good choices. why do the 12th scales use 1/8th diff balls instead of the 3/32 i use in touring. is there a reason or just a prefference thanks |
remember-12th scales came first!! LOoong before Sedans!!
Where did you purchase the Teflon tape? |
Brian- u making the birds?
Re: Re: Cutting the rear axle
Originally posted by rayhuang I wouldnt risk damagng the graphite axle. All the weight is in the center-so it takes very little to accelerate it. And trust me-that axle takes some serious abuse-yo dont want to create a stress riser, etc. |
Originally posted by revzalot Has anyone cut a little bit off the rear axle to reduce rotational mass on their l4? If so how much to cut off? Replace the axle with a hollow Niftech axle. Replace the diff washers with Niftech Rocket Rings. Replace the diff balls with ceramic diff balls. Replace all of the bearings with ceramic bearings. Replace the wheel screws with titanium wheel screws from Lunsford Use an IRS left side clamping hub. Use Parma or TRC wheels as they are the lightest without giving up strength or straightness. |
Originally posted by Crashby If you want to take rotational mass out of the rear of your 1/12th you can do the following: Replace the axle with a hollow Niftech axle. Replace the diff washers with Niftech Rocket Rings. Replace the diff balls with ceramic diff balls. Replace all of the bearings with ceramic bearings. Replace the wheel screws with titanium wheel screws from Lunsford Use an IRS left side clamping hub. Use Parma or TRC wheels as they are the lightest without giving up strength or straightness. |
| All times are GMT -7. It is currently 01:22 AM. |
