-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Mike D 11-21-2003 03:35 PM
Originally posted by Matt Howard
Rugrat owners- are you guys using the screws in the Tbar for side to side tension or the springs on the damper tubes? Or does it really matter which one you use? and another thing, why didn't IRS put some holes in the chassis to mount your servo? seems kinda getto that I have to break out the drill and dremel:confused:
Matt H - The problem is that there isn't an ideal place to mount the servo. Pre-drilled servo holes in 12th scale chassis usually get in the way of where you really want to mount the servo(Murphy's Law of RC). I had 3 sets of mount holes drilled in my prototype rugrat chassis to have the option of moving the servo foward and back over a 1/4". Weight bias and Ackerman changes have a huge effect on corner speed and on overall feel.
stormperson 11-21-2003 04:11 PM
Another way of doing tweak is similar to the penies...
Instead of having penies which tell you which wheel lifted first, you could also look at it straight ahead and see which tire lifts first. Its rather difficult to get the hang of, but I know that Bruce does it this way, and it works very well if you can do it correctly.
jcrouse 11-21-2003 04:33 PM
16 Gauge Silicone "Spaghetti" Wire
Does anyone know of a source for this. Tower shows it but when it arrived it was actually Associated 14gauge, (twice). I also checked with Novak to no avail.
Thanks in advance,
John
fast-ho-cars 11-21-2003 06:14 PM
the wire you seek is available for 1/24 slot cars, the professional type that run on huge wood tracks, use it for guide lead wire, it's a hi-flex multistrand wire. Parma, Koford, Alpha, Slick7 plus more slot car companies have it.
B Kinwald had his R-12 wired up with 16G Novak wire when he was here in AZ on Nov 8.
it's lighter, less interfernce with pod movement...
try these sites
www.ncphobbies.com
www.slotcarcity.com
i have mailordered from both these company's
Grenade10 11-21-2003 08:01 PM
Location of Steering Servo
Mike D
What affect did moving the servo have?
Forward, Back, Flat ect.
Thanks:rolleyes:
disaster999 11-22-2003 01:53 AM
Originally posted by disaster999
ANYone know what compound tires comes with the yokomo YRX12 SSG version?
i was hopping more ppl would know the answer but so far speedxl was the only one answered me and im not sure if he is sure about it. the compound in the kit is most definatly not purple and grey, they are too soft to be greys or purple!
boner 11-22-2003 02:08 AM
GREEN disaster999, GREEN like what I told you at FR tonight.
IMPACTPLAYR 11-22-2003 04:57 AM
POINT blank dude unless otherwise stated, or it's a corally the standrd compound will always be GREEN, if the fronts are harder they will be blues, but only CRC does that when they run short on front greens...........
BTW: I am sure about this, don't think I am not.......:lol: :lol: :lol:
jcrouse 11-22-2003 07:01 AM
Anymore ideas. I couldn't find it on the two links above. I can call tem but would rather just order online. ANy links to the product?
Thanks again,
John
robk 11-22-2003 07:26 AM
Mike D
With that being the case, can you make a recommendation for all the rug rat guys out there?:D :D Thanks
Big KAT 11-22-2003 08:49 AM
Speedxl is correct, Purple fronts & Yokomo L rears.
kansasracer 11-22-2003 08:59 AM
Originally posted by fast-ho-cars
i think you read KANSASRACER wrong? from what i read he has a CK and wants a SM. his hobbyshop don't carry the SM and he has called SM 50+ times and hasn't gotten thru. i know on this one after having tried to call SM, Bruce is tough to get a hold of.
as for parts: other than the graphite pieces, dampners, side link ball studs (CK).....all the rest are AE or DuBro parts
That's exactly right...all CRC, no SM.
Got some offers on some SM thanks...mulling them over...
disaster999 11-22-2003 09:02 AM
try these sites
www.ncphobbies.com
www.slotcarcity.com
just checked out the sites and i never realized how much those controller cost!! it cost more than my futaba 3PJ!!! 280 bucks for a controler that you would find on those tamiya car kits where they include a mechanical speedcontrol.
THEBIGBULL 11-22-2003 09:59 AM
HELP
Boy am I in trouble, I bought Ruben Benitez's last years SM. Last night was the first outing for the car. It is awsome. I promised Ruben I would "TAKE GOOD CARE" of the car . Guess what , I got sent over the boards into a bench int the main. The shock came apart, (end pulled out), NO problem I have a rebuild kit. BUT both inner pieces of the damper tubes broke, (the male ones) where they screw into the ball cup. (Rubens Gunna kill me). We have our first round of the Western Canadian Indoor Carpet series next weekend. Where can I get these quick!!!! I have the only SM car here and there are no spares around yet. YAH I know I should have had some already. Probably a mail order place in the north west would the quickest. I went on SM'S web site this morning , but they list anything for fast service. "HELP"
Terry
:cry: :cry: :cry:
newracer 11-22-2003 10:12 AM
Re: 16 Gauge Silicone "Spaghetti" Wire
Thanks again,
John
www.promatchracing.com has 18ga
www.zagi.com has 16ga
